I thought the Farnell kits did this as standard?
No such luck I am afraid
Seems a shame as I don't think anyone would mind the extra pence to have a few spare in the kit.
Yup. Did the same!ChrisMc wrote:I managed to take the end off the 100uF capacitors when I was trying to tidy up the solder job
Luckily, on a whim, I had bought a 'sample' book of all sorts of values of SMD resistors and capacitors from a Chinese ebay seller (search ebay for #smd sample'), so I could just hoik one out of there!I'm pretty sure if someone started a kit, with two spare of all the surface mounted stuff on ebay, they might be popular.
davej wrote:Post-assembly voltage question:
Assembled, but the voltages at the regulator are out of whack and I have therefor not installed the jumper to feed the board itself.
RPI 5V in : 4V8
RPI 3V3 in: 3V3
Regulator out : 4V3
Is this just a 'no load' issue, or have I gone and messed something up ?
Dave
C1 has some copper running between the two mounting pads, so if your assembly is slightly off you run the risk of bridging to the copper in the middle.
Gert van Loo wrote:C1 has some copper running between the two mounting pads, so if your assembly is slightly off you run the risk of bridging to the copper in the middle.
That should not cause a short as the copper is covered with a solder mask.
Unless you damage the solder mask by scraping it with a metal object (e.g. a soldering iron)
davej wrote:Original question: Got an unexpected high voltage (4V3) on the headers where I was supposed to get 3V3 on the output side of the regulator.
What would have been the best debug approach ?
Yewberry wrote:There's something utterly benign and wonderful about all this Pi stuff, you know
