Today I tried to install Samba and have this
- Code: Select all
pi@raspberrypi ~ $ sudo apt-get install samba
Reading package lists... Done
Building dependency tree
samba is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up samba (2:3.6.6-3) ...
[FAIL] Starting Samba daemons: nmbd failed!
invoke-rc.d: initscript samba, action "start" failed.
dpkg: error processing samba (--configure):
subprocess installed post-installation script returned error exit status 1
samba
E: Sub-process /usr/bin/dpkg returned an error code (1)
This is actually second attempt. First one had the same failure. I did run update&upgrade but only after trying to install samba. So after realising this mistake i removed samba, run update&upgrade then installed samba and it failed again the same way. And /etc/samba doesn't exist after installation although samba installes
