Client Access - to As400 (ISeries)
by darius007 » Sat Nov 03, 2012 10:15 pm
Hi all,
this is a project I'm currently looking at to dramtically reduce the cost of a scanning process in the workplace. Currently we have a PC (linked to the As400) for all of our workstations. Connected to this is a wired LAN connection (usual keyboard and mouse) and a scanner (wedge). Basically, it feels a little 'overkill' to be using a full spec Windows PC to user as an intermediate device just for interfacing with a scanner and the As400.
So, I was thinking - using Debian Squeeze - is there a piece of software out there can allow the PI to link wirelessly to As400 (Client Prog) .... I think VMware is out of scope here ....
Not sure if anyone as had experience with this kind of development .....?
I'm looking at this link at the moment - http://packages.debian.org/stable/tn5250
Who knows? Could be a way of getting the PI into an industrial environment (lol).
by Tbz » Sat Nov 10, 2012 1:24 pm
Hi Darius007,
I'm also interested in installing an AS400 client on a Raspberry Pi.
I'm still waiting for my Pi, but as far as I know, it exists a Linux version of the IBM Access client. OK, it's a .rpm but it's possible ton convert it to .deb thanks to the "alien" command.
For the moment I'm doing some tests inside a virtual machine running Debian Squeeze. Let's hope it'll work and it also work on Raspbian...
If you find out something, please let me know :)
by loudifier » Mon Dec 17, 2012 5:49 pm
Yes, the raspberry pi will work for connecting to the iSeries. I haven't used IBM's linux version of Client Access, but I assume the .rpm contains software compiled for x86 systems, and wouldn't work on the pi.
I have a proof-of-concept up on my site, http://loudifier.com/the-raspberry-pi-is-still-not-going-to-change-the-world/
I used the standard Raspbian wheezy distro, and I am using TN5250 for green screen emulation. The basic setup is:
Raspbian, set up however you want it, running LXDE
Compile and install ncurses v5.9 from source
Compile and install TN5250 v16.5 from source
apt-get install xterm
run xt5250 [iseries IP address]
I am also using a Unitech USB barcode scanner, and it works fine. Since most scanners operate in fairly basic HID mode, pretty much any USB scanner should work fine with the pi.
