I have a small perspex case which is the perfect size for the pi. Is there a material I can put under the pi to cushion it slightly as I don't want the solder pins damaged or scratching of the case. ideally this would be a little foam pad that I could cut to the shape of the pi board minus the sd card holder. something from rs/maplin?
regard
material to rest pi on
