at mine the case doesn't fit at all, i reduced to 92%, is more good now,
but audio and video RCA is decalated...
Alkendi wrote:Thanks very much E for your latest punnet pdf file. I got my Pi yesterday ( Yay!) I bought an A4 sheet of mylar from my local stationers for 35p and laid it on top of your design and traced out the lines and I now have a rather pretty case. I did modify one of the fold over tabs so it slides into a pre-cut slit to hold the case closed. I have attached a pic
meilon wrote:Hi there E,
I have a problem with your SVG version. When I open it in Inkscape, the page is defined smaller than A4 (16.19 x 23.30 cm) and when I try to print directly from Inkscape I only get the left side for the USB and ethernet ports. If I save to a PDF and print from there (using the actual size with latest Adobe Reader), the two 5 cm strips are actually 4 cm width.
How can I mod your great Punnet correctly? I've ordered my RPi yesterday and I'd like to have the case ready for it when it arrives (RS estimation: 10 weeks)
chris_c wrote:....erm is it just me or are more recent pi's slightly different
I used 100gm paper to try it out - its actually good enough for now even with the sellotape)
anyhow the RCA video jack hole seems to be 1 radius (of the jack) too far to the right
everything else like the mic jack hole and hdmi all seem to be okay just the video RCA
chris_c wrote
I made the circular holes square mind as cutting round holes is a pita
I used a method I remembered from many many many decades ago when i was at in my 1st year of school...
I punched lots of holes with a sharp pin (be careful children) round the circumference of the 'holes' and then using a craft knife joined all the holes up leaving a smooth circular aperture with none of those annoying slips of the knife scarring the surface
magarcan wrote:Alkendi wrote:Thanks very much E for your latest punnet pdf file. I got my Pi yesterday ( Yay!) I bought an A4 sheet of mylar from my local stationers for 35p and laid it on top of your design and traced out the lines and I now have a rather pretty case. I did modify one of the fold over tabs so it slides into a pre-cut slit to hold the case closed. I have attached a pic
Were can we found this file?
I have a laser printer at work, but I begin holidays in a few days
. Fabryz wrote:Very nice template, I just printed it on a 220g/m2 to test it out (even if I don't have a raspberry-pi)
Uhm, for some reason my printer didn't print 90% of all the dashed lines
FX4 wrote:This is great, any chance at an 8x11 version. It's a bit hard to come up with A4 stock here in the U.S..
