New Case for the RPI in Shop.
https://www.adafruit.com/products/859
Cases for the Raspberry Pi
JamieR wrote:The nicest looking case i've seen so far is this one http://solidworksbootcamp.com/raspberry-pi-board-b-enclosure/ But it don't seem like you can buy it :/
hi james you dont buy it its a free download file for solidworks and you get a 3d printer to make it for you hows that for free
free link http://bit.ly/wSzlJV
one armed controls engineer, my grammar is bad but lets face it most keyboards don't suit a one armed man
Question
Has anybody got a 3D Cad of the R-Pi ,
My Pi will be about another 6 weeks before I get it , so I'm thinking out with my designing hat and start prototyping a few cases .
A 3D Model will allow me to be more creative with my prototypes , and hopefully the Pi will fit into a Dog / penguin/ Dragon or F1 car shaped case .
Cheers !!
OK , Forum Search actually works well
nemmi69 has a link posted
http://elinux.org/R-Pi_Hub#Resources
Where there are cad files submitted ,
( I'm using Bentley Microstation though so there'll be a Job to get one of those translated into it , )
Many thanks !!
Cheers !!
Many thanks !!
New case from Solarbotics: http://www.solarbotics.com/product/60103/
skater_j10 wrote:New case from Solarbotics: http://www.solarbotics.com/product/60103/
Lol those shipping costs and a $5 handling fee. Yea, I think I'll wait...
It appears the Google sketchup on the Elinux Wiki , is not an accurate 3d of the production model B .
Still it's useful for me to work on to get the basics right ,
I'd still like an official/accurate 3d file of the physical dimensions of the pi , so I can work on designs with confidence .
But no one who may be considered "official" has ever drawn a 3D model of the board. If they drew one now, they would have just as much chance of cocking it up as you would. They may also not use sufficient accuracy for your needs, nor the right file format.
Therefore, if you need a 3D model, you're the best person for the job.
rurwin wrote:But no one who may be considered "official" has ever drawn a 3D model of the board. If they drew one now, they would have just as much chance of cocking it up as you would. They may also not use sufficient accuracy for your needs, nor the right file format.
Rurwin ,
With respect , I haven't got a Pi , nor do I have the schematics ( other than the graphic available here ), nor did I design the Board . So No , I'm not the best person to do this .
When I have the correct ( accurate 3d ) Dimensions for the board ( either when I get my pi and measure them , or if the org actually gets a chance to give them ) I'll surely make my case design available for people to look at , as that will be my work ,
For the time being I'm grateful to be able to work with the kindly user supplied sketchup , even if it is inaccurate ( for the reason of accurate information not being available to that user )
Has anyone done a case yet where they have moved/replicated all the ports so that they are on one side of the case (like say a typical router). Pi is a bit of a mess with cables sticking out on all sides with the cases we see right now.
I've gone with the lego option for now.
Daz555 wrote:Has anyone done a case yet where they have moved/replicated all the ports so that they are on one side of the case (like say a typical router). Pi is a bit of a mess with cables sticking out on all sides with the cases we see right now.
No, but I might mess with that this weekend. I'd have to upgrade my case to a larger tackle box, though.
I only have 2 cables in mine, though: ethernet and power. I'm just running it headless with X forwarding.
markb wrote:If you look at the instructions at stage 6 you put the supports in place, then at stage 7 you are supposed to put in the board - notice how the support nearest to the SD card has suddenly moved to the right.
I think the photos on http://www.thepishop/pihousebuild.htm are correct because they were taken during a real build without moving the parts.
Once you get your head round the fact that you are building it upside down it is straightforward.
I admit the tricky part is step 7 which requires patience. Patience, along with the ability to RTFM, is something we nerds lack (and I am one of the worst!)
Nothing that having three hands couldn't cure of course <g>
BTW: the "forgot to take the blue covering off the plastic bits" club now has six members <g>
Mike,
the issue is that the board is roated 180 degrees between photos 5 & 7.
Mark
Gordon Bennett! You are quite right - thanks!
I must have picked it up and rotated it - but why! I reckon the old brain cell is on the way out.
I have added a suitable notice to http://www.thepishop.org/pihousebuild.htm.
Thanks again.
Thanks again.
Mike Lake wrote:BTW: the "forgot to take the blue covering off the plastic bits" club now has six members
I know
Some further feedback on the PiHouse, swapping the SD card is a nightmare, in fact I can take one out but not re-insert one without taking the case apart. any ideas?
markb
I thought it was the other way round?
I have no problem inserting the SD card (done it a fair bit in the last couple of days with different sized cards, different RPis and different Debians!) - just turn the PiHouse over to see what you are doing.
Getting it out is harder mainly because the SD card holders on my RPis are a good tight fit - they do their best to hang on to the board. However, finger and thumb either side and pull is fine. Again, I do that upside down so I can see the card in the holder as I pull it out.
I notice some of the new RPi competitors are using SD or micro-SD holders and they have put them on the top of the board which makes life a bit easier. See www.ThePiShop.org/value.htm.
The size of the PiHouse was chosen to protect the card when in place - otherwise it is easy to get banged about. (Well, on the mess I call a desk it is!)
You could always house it in a modded Mac Mini case
. I always thought the iBook Clamshell looked nice, if I could just set up an external monitor and keyboard in there that would be perfect.
Ariii
I'm considering an Iomega Minimax that I have lying around ( HD Died , I replaced it with the old 80gb HD from my mini )
viewtopic.php?f=40&t=8260
I might just add an acrylic case to the top and power the Pi from it .
The mini will eventually find some use , stripped down to a server or a music box . I've had it six years now !!
Finally my own case made of laser-cut wood is also ready!
Please take a look here:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=58&t=9584
MINKIN2 wrote:Hi Guys,
I started to look around the house to see if there was anything that could be re-purposed for the Pi board and came up with a couple of simple concept designs
Atari CX – Ri typeB
Rasberry Pi Pod case
Marlboro Pi"s
Ok the last one was just for fun. But I would like to re use one of my battered Pac Man cases if possible. I kept the label design just in case.
How did you make those?
I have just made a case out of a deck of cards. Here are some pics:
https://www.dropbox.com/c/shmodel?nsid=34461056&sjid=0&state=2&signature=808094b&path=/Photos+of+me/1346695457906.jpg&id=shmodel
https://www.dropbox.com/c/shmodel?nsid=34461056&sjid=0&state=2&signature=808094b&path=/Photos+of+me/cardpi.jpg&id=shmodel
Visit my Pi powered Minecraft Server: picraft.no-ip.biz:25565
and my website with instructions on it: www.picraftbukkit.webs.com
