DIY Adafuit Pi Box
by cyanarnofsky » Thu Aug 23, 2012 8:56 pm
Used a router at work, and built the file simply using the wiki image of the case. Will attach vector pdf after I confirm it fits the boards :p just cut.
by adafruit » Thu Aug 23, 2012 9:07 pm
nicely done :)
by cyanarnofsky » Fri Aug 24, 2012 5:02 am
Few more images, of the Pi in the case. fits great, has about 1/8" play inside the box not bad for how it was built :).
by cyanarnofsky » Fri Sep 28, 2012 4:25 pm
Fan mod.
by hoettienouw » Fri Sep 28, 2012 5:59 pm
Can't find the template :(
Could you post it for us :D?
+ how did you cut the plexi and how did you get te template on the plexi ?
by cyanarnofsky » Fri Sep 28, 2012 7:25 pm
I fortunately have a 5'x10' Multicam router table, so I was able to really get precise. Hope this file helps, I am not posting this to under cut anyone simply sharing for personal use.
File:
https://rapidshare.com/files/3125981139/Pi Final Case.pdf
Do not open this file in a program that will rasterize this, will obscure dimensions. Recommend Adobe Illustrator or another vector program.
That material is actually sign grade lexan .25" thick.
by jfornango » Tue Oct 02, 2012 7:43 pm
Lexan? so, it's bullet-proof too? :lol:
I'm only wearing black until they find something darker.
