Hi
I have had a raspberry PI since launch, and have decided it use it to replace my main media center machine. I have recently moved up to the 512mb model, and have noticed how much better it is.
What I would like to do is mod the antec's case to hold the Pi, which should not be an issue. However the LCD screen inside the case has developed a fault, so I would like to replace it with a similar one that is compatible with the PI. If possible I would like this to be soderless (as I cant solder to save my life!)
I would also like to use the SATA DVD drive if possible with the Pi and connect the power up to the 350w psu. Where would be the best place for me to start.
Any Help would be appreciated, thanks
Antec 350 Media Center Mod
The only LCD screen modules which work with a Pi are HDMI ones.
Those are notoriously expensive. But prefab HDMI screens or TVs are cheap
nowadays. Get a SATA-to-usb-adapter , forum member mikerr posted success using those.
DVDs do only work from the command-line AFAIK , and DVD menus don't work.
If i was in your place i would NOT use a PC PSU. It is technically 100% feasible , but
i'd rather not fry myself or worse , the Pi.
ghans
ghans
ghans wrote:The only LCD screen modules which work with a Pi are HDMI ones. ...
ghans
Except that's not the kind of LCD they are talking about. This type of LCD: http://en.wikipedia.org/wiki/HD44780_Character_LCD
Try ebay and look for HD44780 especially one that has a board that supports either I2C or USB.
