Altairst8te74 wrote:All I need now is how to actually get the keyboard talking to the device, can I please have your schematics and stuff?
Everything that's not here is in the technical and hardware reference manuals for the A2000/A500. You can easily identify the pinout in the sourcecode:
- Code: Select all
#define A500CLK 8
#define A500SP 9
#define A500RES 10
#define LED_A 11
#define LED_B 12
So, basically you need a piggyback ('Shield' in Arduino terms) that holds the header for the A500 keyboard connector and wire it up accordingly. If you're not using a Leonardo or its clones, additional work has to be done on the USB connector (did it, but wouldn't recommend it). For a luxery version you need a constant current source for each LED. They take up approx. 100mA each, so cannot be directly connected! The schematics is in one of my posts in this thread.
I have no further pictures and no other schematics. I think this is a task everyone can do on its own who really cares and involves himself in this matter. I as a noob could, and that means something!
BTW, someone in the Arduino forum does an extended version, even integrating successfully Joystick ports and do some optimization! I'm really looking forward to see his work.
Full-time noob forever.
