Debian ARM on Raspberry Pi
136 posts   Page 1 of 6   1, 2, 3, 4, 5, 6
by Michael » Fri Feb 17, 2012 11:55 pm
A Debian Squeeze reference root filesystem is now available on the downloads page. This image has been put together by Gray and Dom and contains LXDE, Midori, development tools and example source code for multimedia functions.
This disc image is not the one we expect people to be using as standard (that’s from Fedora, and has some other exciting stuff bundled with it, which we hope to be putting up over the next few days).  This is the file system that the Cambridge Raspberry Pi staff have been using for demos, testing, providing to with alpha boards to third-party developers and so on.
More information:
http://www.raspberrypi.org/archives/645
Announcement in the General Discussion forum:
http://www.raspberrypi.org/for.....o-download
For an idea of packages available for ARM that could be made to work on Raspberry Pi, try:
http://packages.debian.org/sta.....llpackages
by smuggly » Sat Feb 18, 2012 12:23 pm
Any one know where a guy can get good info on dd or a gui to write to a sd card for the img file? Thanks
by smuggly » Sat Feb 18, 2012 12:38 pm
I found one gdiskdump, I got a deb file i downloaded. It should be good for us terminal challenged In the Cyberland. I'm getting better with the cl but, I always get mixed up on my syntax! The memory isn't what it was :)
by riggsre » Sat Feb 18, 2012 3:12 pm
You guys are way ahead of me using Linux. I hope this helps other beginners.
I downloaded the Debian Squeeze from http://www.raspberrypi.org/downloads and unzipped it.
I loaded Fedora 14 on a Vitrual machine. I put the unzipped img file in Documents, opened a terminal window typed cd Documents (enter) then typed su (enter) and put in my password (you won't see the password or any "*" or anything) and press enter again. Then type:
sudo dd if=debian6-17-02-2012.img of=/dev/sdb bs=1M
Press enter.
(credit Carlos on February 17, 2012 at 11:08 pm)
I had to wait about 5 minutes (maybe longer - no feedback) before the cursor came back. You will have to eject the SD card and reinsert it and it should look something like this:
Dir
I don't know yet if it will work. No way to test it.
by grumpyoldgit » Sat Feb 18, 2012 3:20 pm
I'm assuming that as you are loading a virtual Linux system and then using that to copy the image to an SD card, you are probably using Windows. There is a WinDD equivalent so really don't need to go through all the Fedora virtual machine stuff.
by smuggly » Sun Feb 19, 2012 4:14 pm
Ubuntu
by ozzle » Tue Feb 21, 2012 7:03 pm
The same command works in Ubuntu.
If you are having trouble finding the device name of the SD card try the following command: dmesg | tail -20
Good luck!
by Ron Broberg » Sun Feb 26, 2012 2:59 pm
I'm not sure if user 'nmcc' used this image for his emulator setup  ( see http://www.raspberrypi.org/for.....-downloads ),
but here are the notes for my build of OpenMPI
OpenMPI on Raspberry Pi
by shirro » Sat Mar 03, 2012 3:10 am
I have been using .deb based systems for too long to be bothered changing to Fedora I think. Considering the scale or the Raspberry Pi launch is there any chance Debian might be recompiled with hardfloat or Canonical might be convinced to build an ARMv6 target?
[EDIT: I just read a bit of background on Canonical's lack of helpfulness and I am starting to think they have lost the plot completely. I withdraw that suggestion.]
by esbeeb » Mon Mar 05, 2012 6:37 pm
Can anyone speak to just how much real-world performance is actually lost due to Debian not being natively compiled for ARMv6 (like the Fedora remix is?)
Would natively re-compiling Debian for ARMv6 just bring a Gentoo-esque 1 or 2% performance gain, which would be barely perceptible to the end user?
by simbad » Mon Mar 05, 2012 10:25 pm
Can rasberry run ubuntu or backtrack since both are based on debian? Thanks
by markb » Tue Mar 06, 2012 6:01 am
As I don't have access to a linux build at the moment, would the command using windd be:
windd if=path-to-debian-zip of=path-to-SD-card bs=1M
by Chromatix » Tue Mar 06, 2012 6:08 am
Don't bother with WinDD, there's a much easier and more reliable tool available from the Ubuntu folks.
The key to knowledge is not to rely on people to teach you it.
by markb » Tue Mar 06, 2012 8:17 am
Which is please?
by esbeeb » Tue Mar 06, 2012 5:02 pm
I feel the same way as you.  If I had my Druthers, Ubuntu would be the premier distro of the RPi, but failing that, I would want Debian as the "runner up", not Fedora.  I started with Redhat 4.1 way back in the day, but once I moved from Redhat to Debian a few years later, and beheld the power of APT, there was no going back (to an RPM-based distro).
Surely there is a chance.
I know this is some Pi-in-the-Sky dreaming, but I hope some Debian-friendly philanthropist (other than Mark Shuttleworth) out there (or Debian-friendly software consultancy looking to do some "sponsoring" for the sake of some awesome, inexpensive PR) with, say, $700ish to invest (and some SysAdmin skills) builds a cluster of, say, 10 Raspberry Pi's, then politely invites key Debian ARM porting developers (like, say Riku Voipio, Martin Michlmayr, and/or Aurelien Jarno from Debian) to remotely log into said cluster to possibly do the building of all the Debian package repositories for ARMv6.
I mean come on, doesn't anyone want to be the first to brag about having the "Cheapest Debian Cluster Ever"? ;)  Think of it: a whole cluster for the price of one half-decent PC!  Never mind the millions that Mark Shuttleworth invested, this is some serious bang for the buck.  I think this would generate some serious geek "street cred".
(Note: having said that, I haven't got the means to do this myself.)
by esbeeb » Wed Mar 07, 2012 12:50 am
Aargh.  From a bit of reading at Debian''s website, it looks like it could be quite a bad performance loss (at least whenever one is doing anything that heavily relies on floating point operations):
"Genesi USA, Inc. did a proof-of-concept rebuild of Ubuntu karmic (9.10)'s armel port with the hard-floating. They noticed important wins (in the order of 40% performance improvement) in floating-point heavy applications/libraries such as mesa, with a Cortex-A8 CPU."
Note: The Cortex-A8 mentioned above is ARMv7, whereas the Raspberry Pi is only ARMv6.  So that''s not an apples-to-apples comparison.  I''m still awaiting to see a fair comparison of hardfloat-vs-no-hardfloat on the Raspberry Pi's ARMv6.
So what hope is there of Debian officially compiling hardfloat support for the RasPi?
It would seem none, at the moment.  Maybe we should all petition them to include it?  We''d have to act fast, before Debian's upcoming freeze occurs "sometime in the middle of 2012".
The current situation seems to go something like this: Even though the Raspberry Pi''s ARMv6 processor has "hardware floating point" (the CPU feature is called "VFP"), Debian''s current, official "ARM EABI" port (for Debian 6) unfortunately does not compile support for VFP in!
In other words, once all the new Rasberry Pi users install Debian for the first time, as it currently stands, they might be disappointed to discover that their floating point hardware functionality just sits there, affectively unusable.  All floating point operations (think "Multimedia") will instead be done using software-based emulation, incurring a substantial loss in performance.  Am I right on this?
To make matters worse, Debian is cooking up a new official port for the ARM, called "ArmHardFloatPoint", which they hope to officially include in Debian 7.  But it will only cover ARMv7 (which have VFP), and above (think BeagleBone).  So, as it stands, the Raspberry Pi will "miss the boat," since it's only ARMv6.
Failing convincing Debian to officially include support for the Raspberry Pi's hardware floating point in Debian 7, the only other option will be to make an "unofficial" port (akin to how there is a "Remix" of Fedora for the Raspberry Pi.  This would necessitate a group of avid Raspberry Pi fans making (or getting access to) their own build cluster (like Seneca College did), and rebuilding all the Debian packages, compiling for the ARMv6 with hardware float support.  Then they would also have to make their own package repositories, security update packages (in a timely, consistent manner), website, etc.  That might be a lot of work!
Any corrections or additions to the above would be most appreciated.
In summary: perhaps I''ll just think twice about using some different compile-optimized distro on the Raspberry Pi, after all.  I''m starting to warm up to Puppy, since it's been painstakingly designed specifically to run nicely in 256 MB RAM (for a long time now).
by esbeeb » Wed Mar 07, 2012 8:55 pm
It seems there is already someone named Mike Thompson, who wants to port Debian to the Raspberry Pi.  And it seems the "Debian port to ARM" mailing list is the place to further discuss this.
by Chromatix » Wed Mar 07, 2012 9:13 pm
FYI, I did already establish that the performance impact of softfloat/softfp/hardfloat is broadly comparable between ARMv7 and ARMv6.  Whichever CPU you use, it's a *big* difference if you have an FP-heavy workload.
Specifically, I developed a tiny benchmark using my TrimSlice (ARMv7) and measured a big difference there.  I then managed to get someone with a beta board to run it, and they got numbers that were entirely consistent with my expectations.
This led fairly directly to the Gentoo hardfloat thread further down this section of the forum.  It also convinced Broadcom to release a hardfloat version of the GPU interface libraries, which are needed for compatibility with a hardfloat distro and which should benefit in terms of performance too.
The numbers:
- Expect a tenfold improvement in FP performance for moving away from softfloat (to softfp or hardfloat) on a VFP-equipped CPU.
- Expect a threefold reduction in function call overhead for functions with floating-point arguments and/or return values, when moving from softfp to hardfloat.
- For a trivial function that computes a dot-product between two 2 vectors, total performance was roughly doubled when moving from softfp to hardfloat.
Inlining gave even more performance, mostly because some of the calculation could be hoisted out of the innermost loop, but that was actually a smaller effect.  The raw function-call overhead in the hardfloat case was simply the BX LR instruction to return with.
by esbeeb » Fri Mar 09, 2012 4:57 pm
Good news for Debian fans: It would seem that the Debian ARM porters are now actively discussing (on the "Debian port to ARM" mailing list) how to go about making some kind official Debian port for the Raspberry Pi.  Unfortunately, as of yet, none of them have any Raspberry Pi hardware (or remote login access to any).  Hint: Anyone wanting to help them out by allowing them the use of their Raspberry Pi for compiling packages would probably be helpful and appreciated! :)
by pilouccio » Fri Mar 09, 2012 8:06 pm
The little Pi is soon at home.
I would like to use it for networking especially SMB and netatalk without graphical GUI.
I trained myself on virtual box with a very basic version on Debian in text mode adding package that i need using apt which is very easy to manipulate for a half beginner.
It looks like that a lot of ARM package are available in Debian repository. That make my choice for that destro.
Is someone knows a method or an existing image to load a basic version of Debian (the 180 Mo version) on the SD card ?
A kind of tiny Debian for Raspberry Pi !
by vodor48 » Thu Mar 22, 2012 10:05 am
Hi All!
/sorry, for my bad english/
I need some help.
Download the Debian6-17-02-2012.zip and unzipped and write the .img to sd card, used WIN32DiskImager.
Try booting in QEMU, but something wrong. Qemu always "say": No bootable device.
Please, somebody write the good, working qemu command this Debian?
THX
by rmm200 » Thu Mar 22, 2012 8:39 pm
Can we get IPV6 enabled in the next Debian kernel? Should be no down side.
by rurwin » Thu Mar 22, 2012 9:12 pm
vodor48 said:
Hi All!
I need some help.
THX
You do not need to write the image to an SD card. That is only for a real Raspberry Pi. QEMU works from the img file.
Moderator
by vodor48 » Fri Mar 23, 2012 12:12 pm
Thanx your reply!
Sorry, write wrong.
First I try booting the .img file and after write to sd card and try boot again.
by rurwin » Fri Mar 23, 2012 12:22 pm
No. Forget the SD card until you have a Raspberry  Pi board in your hand.
QEMU works from the image of the SD card — the img file.
Read this thread for instructions: virtualbox simulator and emulator now with added cow
Moderator
