Script for text to speech
by ax206geek » Thu Jun 28, 2012 1:28 pm
8-) A little debian script to get your R-Pi to speak to you:
Sorting out the dependency
sudo apt-get install mplayer
The script itself:
#!/bin/bash
say() { local IFS=+;/usr/bin/mplayer -ao alsa -really-quiet -noconsolecontrols "http://translate.google.com/translate_tts?tl=en&q=$*"; }
say $*
You probably need to modprobe snd_bcm2835 as well. The R-Pi's speech is output from hdmi so my /boot/config.txt contains this line:
hdmi_drive=2
A little test
./speak my raspberry pi speaks to me
by mikerr » Mon Jul 02, 2012 5:37 pm
Good idea using google's text-to-wave engine, but that will obviously only work if the pi always has internet access.
Festival TextToSpeech worked straightaway for me on debian wheezy:
apt-get install festival
uses around 20MB on the SD card.
echo "I'm sorry dave, I'm afraid I can't do that" | festival --tts
Pi count: 4 - File & print server / Wifi Webcam server, XBMC and tinkerPi !
