Well, it's not polished yet, but preliminary tests show that the Raspi has enough power to do some simple NFM software-defined radio work with RTL2832U-based DVB-T USB TV tuners.
I was able to compile rtl_fm (an optimized version of Osmocom's rtl-sdr software), which allowed the Raspi to tune a frequency (162.55 MHz, weather radio band in the US) and play it real-time. The Raspi's internal sound kept hanging, so a cheap USB audio device was used instead. The audio is choppy, but CPU usage is only around 62% - which is promising.
Raspi and RTL-SDR
Was the dongle powered by the Pi or externally?
By the Pi. The Pi itself was powered with a 2A power supply (originally an HP Touchpad power adapter).
Thought ot using the Pi as a USB-IP converter and piping the feed back to a more powerful PC running an SDR app in a VM?
Would this work? You can get away from thePC's RF noise, and keep the tuner close to the antenna this way..
