Motion dont work
I had set up motion on my raspberry pi but when i open it in firefox with ip:8081 i se one frame then i turns gray and says unable to open video device ;( I run debian squeze and the camera is an eyetoy Somebody knows what wrong?
sleipner42 wrote:I had set up motion on my raspberry pi but when i open it in firefox with ip:8081 i se one frame then i turns gray and says unable to open video device ;( I run debian squeze and the camera is an eyetoy Somebody knows what wrong?
Hi, have you updated the firmware on your pi? Have you checked your settings in /etc/motion/motion.conf, try lower widthxheight resolution and make sure your framerate isn't too high.
I found with higher settings (and in absence of hard float) that the Pi cant handle motion much beyond 320x240.
ash
EDIT: check and post your output when you start motion from the terminal, that will help us help you
Yes i have latest update and run on very low settings in motion, 320 x 240 and 2 fps, i see one frame so the webcam works. Here is the output:
It runs fine until first "Corrupt JPEG data: premature end of data segment".
- Code: Select all
pi@raspberrypi:~$ sudo motion
[0] Processing thread 0 - config file /etc/motion/motion.conf
[0] Motion 3.2.12 Started
[0] ffmpeg LIBAVCODEC_BUILD 3412993 LIBAVFORMAT_BUILD 3415808
[0] Thread 1 is from /etc/motion/motion.conf
[0] motion-httpd/3.2.12 running, accepting connections
[1] Thread 1 started
[0] motion-httpd: waiting for data on port TCP 8080
[1] cap.driver: "ov519"
[1] cap.card: "EyeToy USB camera Namtai"
[1] cap.bus_info: "usb-bcm2708_usb-1.2"
[1] cap.capabilities=0x05000001
[1] - VIDEO_CAPTURE
[1] - READWRITE
[1] - STREAMING
[1] Config palette index 8 (YU12) doesn't work.
[1] Supported palettes:
[1] 0: JPEG (JPEG)
[1] Selected palette JPEG
[1] Test palette JPEG (320x240)
[1] Using palette JPEG (320x240) bytesperlines 320 sizeimage 29390 colorspace 00000007
[1] found control 0x00980900, "Brightness", range 0,255
[1] "Brightness", default 127, current 127
[1] found control 0x00980902, "Color", range 0,255
[1] "Color", default 127, current 127
[1] mmap information:
[1] frames=4
[1] 0 length=32768
[1] 1 length=32768
[1] 2 length=32768
[1] 3 length=32768
[1] Using V4L2
[1] Resizing pre_capture buffer to 1 items
[1] Started stream webcam server in port 8081
[1] File of type 8 saved to: /tmp/motion/01-20120627171659.swf
[1] File of type 1 saved to: /tmp/motion/01-20120627171659-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171700-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171700-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171701-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171701-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171702-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171702-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171703-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171703-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171704-00.jpg
[1] v4l2_next: VIDIOC_DQBUF: EIO (s->pframe 2): Input/output error
[1] File of type 1 saved to: /tmp/motion/01-20120627171704-01.jpg
[1] v4l2_next: VIDIOC_QBUF: Invalid argument
[1] Video device fatal error - Closing video device
[1] Closing video device /dev/video0
[1] File of type 1 saved to: /tmp/motion/01-20120627171708-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171708-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171709-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20120627171709-01.jpg
[1] Retrying until successful connection with camera
[1] - VIDEO_CAPTURE
[1] - READWRITE
[1] - STREAMING
[1] 0: JPEG (JPEG)
[1] frames=4
[1] 0 length=32768
[1] 1 length=32768
[1] 2 length=32768
[0] httpd quit
[0] httpd - Read from client
[0] httpd Closing
[0] httpd thread exit
[1] 3 length=32768
[1] Error starting stream VIDIOC_STREAMON: Input/output error
[1] ioctl (VIDIOCGCAP): Inappropriate ioctl for device
[1] File of type 1 saved to: /tmp/motion/01-20120627171710-00.jpg
[1] Thread exiting
[0] Motion terminating
pi@raspberrypi:~$
That doesn't look like a ps3 eye toy to me, is it an old eye toy?
Its the ps2 eyetoy.
sleipner42 wrote:Its the ps2 eyetoy.
Is it a previously known supported webcam? I dont think it is ... http://elinux.org/RPi_VerifiedPeripherals#USB_Webcam
ashbash wrote:sleipner42 wrote:Its the ps2 eyetoy.
I tried a logitech quickcam with ext. power and i runs fine a while then i get this same error:
- Code: Select all
[1] File of type 1 saved to: /tmp/motion/01-20120629084021-01.jpg
[1] v4l2_next: VIDIOC_QBUF: No such device
