FM Radio
by bluseychris » Wed Jun 20, 2012 7:54 am
Is it possible to build an FM radio kit and send that through the GPIO to be played through speakers/headphones?
I know that there are FM Radio dongles out there, I just thought it would be more fun to build a kit and plug that in. Add an old AM kit and you can pop a switch in that flips between them.
by godFather89 » Wed Jun 20, 2012 9:06 am
It's not easy to build a decent FM receiver.
There are I2C FM modules which could be controlled directly with the RPi but for the audio to get back in the RPi, you would need a USB sound card with audio input.
by thekeywordgeek » Wed Jun 20, 2012 3:24 pm
This might not be the solution you're looking for, but how about a software defined radio using a USB digital TV receiver?
http://sdr.osmocom.org/trac/wiki/rtl-sdr
by bluseychris » Wed Jun 20, 2012 4:20 pm
Thanks for that, I'll have a look at both options. The idea is to create a small always on system that doubles as a music player/radio/alarm clock with buttons, switches and knobs for setting time, alarm, on/off and all that. Maybe add an LCD screen for display as to what track is playing when songs change or frequency/station name.
by bonelifer » Thu Jun 21, 2012 7:23 pm
After looking around my thoughts were to just use the RPi to control the radio via a website(php) interface. I found a I2C FM module on EBay: LINK HERE That seller also has many different prebuilt amplifiers that could be used. You could use a Y cable to connect the FM module and a usb sound card(to use something like mpd for online radio sources). For a couple dollars more you could get this SiliconLabs based module that also supports "detecting and processing both Radio Data Service (RDS) and Radio Broadcast Data Service (RBDS) information. The Si4703 even does a very good job of filtering and carrier detection. It also enables data such as the station ID and song name to be displayed to the user." at LINK HERE Then you could display the RDS/RBDS/Station FREQ info or internet info on a lcd.
Unfortunately I couldn't code my way out of a box.
Location: http://www.phpbb.com/community/memberlist.php?mode=viewprofile&u=147848
by bluseychris » Fri Jun 22, 2012 12:05 am
bonelifer wrote:After looking around my thoughts were to just use the RPi to control the radio via a website(php) interface. I found a I2C FM module on EBay: LINK HERE That seller also has many different prebuilt amplifiers that could be used. You could use a Y cable to connect the FM module and a usb sound card(to use something like mpd for online radio sources). For a couple dollars more you could get this SiliconLabs based module that also supports "detecting and processing both Radio Data Service (RDS) and Radio Broadcast Data Service (RBDS) information. The Si4703 even does a very good job of filtering and carrier detection. It also enables data such as the station ID and song name to be displayed to the user." at LINK HERE Then you could display the RDS/RBDS/Station FREQ info or internet info on a lcd.
I can't code either, though I did find the GPIO switch demo on Youtube and drivers for various USB sound cards so that is part of the way there. If I can tell the Rpi to flash LEDs I can change the code to tell it to shift frequency, turn sound on and off in the system mixer. I had a thought about using something along the lines of an old atari control paddle for that, though that'd require more than i know.
Thanks for those tips, I'll have a look around for drivers for that chip.
by bonelifer » Fri Jun 22, 2012 12:30 am
Not sure what level of hardware hackery you are capable of but you could use a usb keypad(similarly to what they describe here):
http://www.glenalec.net/DMCTO/samples/h ... ndex.shtml
by bluseychris » Fri Jun 22, 2012 12:48 am
bonelifer wrote:Not sure what level of hardware hackery you are capable of but you could use a usb keypad(similarly to what they describe here):
I could but that takes most of the fun out of it :D
[ninja edit]
AH! Sorry, that looks like it could be quite fun :) Teaches me to follow links afterward, thought you menat use a keypad to type in stuff in a keyboard manner. I'd probably use that for all the sleep/snooze/off settings on the alarm If I'm honest though there's something alluring about the breadboard and expansion boards that makes me want to hardwire it all in.
[/ninja edit]
I was thinking of using some of these saftey cover switches to flick the sound on and off.
The idea would be to modify an audio jack adapter so that both the system sound and the radio sound go into it, then have the switch as a main on off for the radio (the idea is that it's an always on system after all). Not sure if that would work, or if any linking cable between the board's jack and the adapter could be attached to an old style chrome antenna, like the old portable radios used to have.
There's a couple of thought's anyway.
by Kennet » Sun Jul 01, 2012 5:20 pm
I think you could use the FM Radio (also have RDS) http://www.sparkfun.com/products/10344
I have used it with Netduino. I haven't got my RPI yest so I can test.
