I tried to get jackd running, but failed.
Anyone tried an succeded ?
Performance wise it might just be enough to run
aeolus or freewheeler
best regards
Matthias
jackd ?
Hi Matthias,
I've had the same problem. The jackd package installed without errors, but the server hangs during the initialisation stage, and never returns the command line. If you add the -v verbose flag, you'll see (or at least I see) that the last message before it hangs is
Jack: JackEngine::NotifyAddClient: name = system
Maybe that would help some experts identify what the problem is.
It would be great to get this solved, as pretty much 100% of Linux sound creation programs rely on JACK.
Sam
Sam
If you have a usb sound card, you may want to try jackd1 (jackd2 is installed by default, at least on debian, if you install the jackd pseudo-package).
Regarding the built in sound it's sadly a no go, see this topic.
