- Code: Select all
0:00:00.057449047 4946 0x471400 INFO GST_INIT gst.c:456:gst_init_check: initialized GStreamer successfully
0:00:00.114783093 4946 0x471400 ERROR omx gstomx.c:2040:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs
0:00:00.120135191 4946 0x471400 WARN GST_PLUGIN_LOADING gstplugin.c:559:gst_plugin_register_func: plugin "/home/pi/omx/lib/gstreamer-0.10/libgstopenmax.so" failed to initialise
Where/what is this configuration/key file!
Edit: there is a broadcom gstomx.conf file in the debian directory or the omx-debian tree...
