FM Radio....
by mikerr » Sat Jul 14, 2012 4:09 pm
The beginnings of a car radio project...
I've found this old radio card I had lying around and it is supported by Debian Wheezy on Pi:
but no radio app is installed by default in X,
I'll be running in console anyway, so I went to get a radio app:
sudo apt-get install radio
radio -s
(the -s auto scans for stations)
http://linux.die.net/man/1/radio
Not pretty, but it'll be used without a monitor, with a few buttons on the GPIO pins.
"Stay tuned" for the rest of the project....
Pi count: 4 - File & print server / Wifi Webcam server, XBMC and tinkerPi !
by david_Est » Thu Sep 06, 2012 5:14 pm
What is the exact model of the radio? would this: http://www.amazon.com/ADS-RDX-155-EF-In ... B000HNHA12 work on raspberry?
by mario » Thu Sep 20, 2012 2:21 pm
Does this device work directly connected to the onboard USB ports or do you have to use a powered hub?
Maybe there´s a way to use this FM receiver to send remote commands to the Raspi.
by pygmy_giant » Thu Sep 20, 2012 5:11 pm
You have more pi's and hardware than is healthy for one person - you can get help, but first you have to admit you have a problem.
Ostendo ignarus addo scientia.
by ghans » Thu Sep 20, 2012 9:11 pm
I agree with pygmy_giant. :lol:
Nice post as always , mikerr :D
ghans
by mikerr » Fri Sep 21, 2012 8:32 am
Lol - too many pi you say ? Never...
I do hoard old hardware, but "it'll come in useful one day" :)
by bonelifer » Fri Sep 21, 2012 7:21 pm
I got the US radio awhile ago and it's just set around due to other things. I wonder do you know what kind of plug the antenna is using? Thinking of trying to flush mount a panel mount on the back of the case.
Location: http://www.phpbb.com/community/memberlist.php?mode=viewprofile&u=147848
by bonelifer » Sat Nov 03, 2012 10:17 pm
Wish there was a addon for XBMC.
by canibalimao » Tue Dec 18, 2012 2:13 pm
I want something like this too, but I think I can't get one of those dongles here in Europe. Anyone knows if there is other devices compatible with the RPi?
by officerNordberg » Fri Jan 04, 2013 2:18 am
Any luck with this? I've got the same dongle and it finds stations on scan but I cannot hear any audio. I've tried radio and I've tried piping arecord to aplay.
by dhead » Thu Feb 28, 2013 12:59 am
I also struggle to get this device work in linux.
I believe the issue is that the firmware of the device isn't updated.
I've complied an updated firmware from the sources on silabs site as binary and hex files but I don't have any suitable programer (and won't get one just for this).
There was an initial support for flashing the firmware on linux but it never made into linux, I've tried to get these changes into a more recent driver but had some issues with it.
http://members.efn.org/~rick/work/pcear/
by tonyhughes » Thu Feb 28, 2013 1:19 am
MMmm.... I think I want to do this, to roll my own podcasts of radio shows that don't have podcasts.
by JustJ » Fri Mar 15, 2013 1:40 pm
Hi mikerr,
you've left us hanging. Does this really work? I have one of these devices - Instant FM Music, Part Number: RDX-155, FCC: LL5-RDX-155. Is this the one you have? I tried this with Raspian(Kernel: Linux raspberrypi 3.6.11+) but can't get it to work. "radio -s" complains that there is no radio0 file or directory. Please help with your configuration. Appreciate a response. Thanks much.
by JustJ » Sun Mar 17, 2013 12:16 am
I tried this USB radio on Ubuntu today and it works(as per the instructions here). Three modules are necessary:
radio-usb-si470x
snd_usb_audio
usbhid
Number 2 and 3 are already available on the Pi.
The module(driver) missing for the ADS RDX-155 to work on Raspbian is not compile on the image that I am currently using (Linux raspberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l GNU/Linux). Can someone please compile and post the module for si470x(radio-usb-si470x)? Thanks much.
by JustJ » Tue Mar 19, 2013 1:22 pm
Finally got this thing working. The latest Wheezy Raspbian image(2013-02-09-wheezy-raspbian.zip) not does come wit the radio-si470x-usb module. I cross-compiled my own kernel and modules on Ubuntu 12.04 64bit and now can use the USB radio on the PI. Audio from the USB card must be piped to the sound card using arecord and aplay like this:
arecord -q -c 2 -D hw:1,0 -r 96000 -f s16_LE | aplay -q -B -
Now I'm faced with another big issue - Underruns!!! A loud popping noise is sent through my speakers each time(approx every second) an underrun is experienced making the radio virtually unusable. Can anyone help with this issue? Thanks in advance.
by dhead » Thu Mar 21, 2013 7:28 am
JustJ, thanks for the hints.
I've finally stopped working with vm's and installed linux on my laptop and the device works flawlessly.
I'm using fmtools to tune in and arecord|aplay to listen to the stream.
I've no issues with the device, maybe your issue related to usb power issues, try a powered usb hub.
The next step for me will to find the best way to use the tuner with xbmc.
One solution is to use vdr's vdr-plugin-pvrinput, I'm not sure if this works with usb radio tuners.
Second solution is to broadcast the stream and to use ssh to send tune commands.
My favorite solution would be to find a way to use the device with tvheadend, a quick solution would to broadcast the stream over ip and use tvheadend to initiate a tune fm command when activating the channel, this would need some coding and I have a pretty basic knowledge in c and no much in c++ but I'm guessing others will have interest in initiating commands on channel switch because this also will enable to initiate lirc command through ir blaster, so it might be a good project.
I'm still looking for other devices,
the good old wintv pvr usb2 should work great with vdr-plugin-pvrinput and it can tune also to am,
Rtl-sdr is also a cheap and capble and if I understood correctly with the proper hardware adjustments it can tune to am, I didn't had success with the rtl_fm tool, although I can tune with sdr# but it's quiet heavy on resources.
And of course there are more diy project especially for the Raspberry Pi, but currently I'm looking for the faster to get this up and running and for a platform dependent solution.
by JustJ » Thu Mar 21, 2013 12:25 pm
It works well on my desktop. I've tried it with Gnome Radio and the terminal "radio" app and I have no problems. The audio underrruns are only being experienced on the Pi. I ordered a power USB hub and will report back when it arrives. But I have read numerous posts on the Internet with folks complaining about USB sound cards on the Pi. Hopefully it's not that. Do you have a Pi with a powered USB hub? Maybe you can tell me how this works for you. Thanks.
by dhead » Fri Mar 22, 2013 11:44 am
I haven't tried it with my Raspberry, yet, and giving this a second thought maybe limiting the usb hub on the Raspberry to usb1.1 as done with external usb sound cards also will fix this issue, meaning adding dwc_otg.speed=1 to cmdline.txt.
The issue with this solution is that you're limited to use devices that support usb1.1, this can be problomatic with usb keyboards and mice.
