Dex (me)
Stephen
TonyMac
Worked on a ver for DexOS (it a OS)
most of the work for the dexos ver was done by Stephen, just for fun i knocked up a simple ver x86 32bit linux (less than half a hour).
FBasic_L.inc
- Code: Select all
; FBasic is based on a idea by rCX, for a fasm macro basic.
; The esae of basic, with the power of ASM.
; Code input by:
; Dex
; rCX
; Stephen
; TonyMac
; This include is for 32BIT Linux terminal.
; File header. ;
format ELF executable ;
entry start ;
; CLS. ;
macro CLS ;
local .Done ;
local .a ;
local .b ;
mov eax,4 ; Print function
mov ebx,1 ;
mov ecx,.a ;
mov edx,.b ;
int 80h ;
jmp .Done ;
.a db 1bh, "[2J",1bh, "[01;01H" ; clear screen.
.b = $-.a ;
.Done: ;
; PRINT. ;
macro PRINT String{ ;
local .Done ;
local .a ;
local .b ;
mov ebx,1 ;
mov ecx,.a ;
mov edx,.b ;
int 80h ;
jmp .Done ;
.a db String,0xa ;
.b = $-.a ;
.Done: ;
; LOCATE. ;
macro LOCATE col,row ;
local .Done ;
local .CursorX ;
local .CursorY ;
local .ColumnRow ;
local .ColumnRowSize ;
pushad ;
mov dh, 10 ;
mov ax, row ; AX = character column
and ax, 0FFh ;
div dh ; divide by 10
add ax, "00" ;
mov [.CursorX], ax ;
mov ax, col ; AX = character row
and ax, 0FFh ;
add ax, "00" ;
mov [.CursorY], ax ;
mov ebx,1 ;
mov ecx,.ColumnRow ;
mov edx,.ColumnRowSize ;
int 80h ;
jmp .Done ;
.ColumnRow db 1bh, "[" ; cursor positioning sequence
.CursorX dw 0 ;
db ";" ;
.CursorY dw 0 ;
db "H" ;
.ColumnRowSize = $-.ColumnRow ;
.Done: ;
popad ;
; END. ;
macro COLOR NewColor ;
local .Done ;
local .Done1 ;
local .black ;
local .red ;
local .green ;
local .yellow ;
local .blue ;
local .magenta ;
local .cyan ;
local .white ;
local .Size1 ;
local .Size2 ;
mov al,NewColor ;
cmp al,15 ;
ja .Done ;
cmp al,15 ;
jne @f ;
mov ecx,.white ;
jmp .Done1 ;
cmp al,0 ;
jne @f ;
mov ecx,.black ;
jmp .Done1 ;
cmp al,11 ;
jne @f ;
mov ecx,.cyan ;
jmp .Done1 ;
cmp al,12 ;
jne @f ;
mov ecx,.red ;
jmp .Done1 ;
cmp al,14 ;
jne @f ;
mov ecx,.yellow ;
jmp .Done1 ;
cmp al,10 ;
jne @f ;
mov ecx,.green ;
jmp .Done1 ;
cmp al,13 ;
jne @f ;
mov ecx,.magenta ;
jmp .Done1 ;
cmp al,9 ;
jne @f ;
mov ecx,.blue ;
jmp .Done1 ;
jmp .Done ;
.Done1: ;
mov ebx,1 ;
mov edx,.Size2 ;
int 80h ;
jmp .Done ;
.black db 1bh, "[0;30;49m" ;
.red db 1bh, "[0;31;49m" ;
.green db 1bh, "[0;32;49m" ;
.yellow db 1bh, "[0;33;49m" ;
.blue db 1bh, "[0;34;49m" ;
.magenta db 1bh, "[0;35;49m" ;
.cyan db 1bh, "[0;36;49m" ;
.white db 1bh, "[0;37;49m" ;
.Size1 db 1bh, "[0;39;49m" ;
.Size2 = $-.Size1 ;
.Done: ;
; GOTO. ;
Macro GOTO _op1 ;
jmp _op1 ;
; GOSUB. ;
Macro GOSUB _subname ;
call _subname ;
; RETURN. ;
Macro RETURN ;
ret ;
; SLEEP. ;
macro SLEEP ;
pushad ;
mov eax,3 ;
xor ebx,ebx ;
mov ecx,1 ;
mov edx,buffer ;
int 80h ;
popad ;
; END. ;
macro END ;
local .Done ;
local .restore ;
local .Size2 ;
pushad ;
mov ecx,.restore ;
mov ebx,1 ;
mov edx,.Size2 ;
int 80h ;
mov eax,1 ; Exit function
xor ebx,ebx ;
int 80h ;
jmp .Done ;
.restore db 1bh, "[0;39;49m" ;
.Size2 = $-.restore ;
.Done: ;
popad ;
; START of Program. ;
segment readable writeable executable ;
buffer rb 1 ;
start: ;
Its just a cut down ver of DexOS one, that Stephen work on, you can find him on the DexOS forum.
We add some commands from darkbasic for high res graphic modes
If you want it to run bare metal or on the linux on the R-PI it would just need to be written in with FasmArm.
This is a basic example it could be done in a python like language.
Or even a raspberrypi language
