Cannot install wview into Raspbian
by damefrikis » Thu Aug 02, 2012 2:03 pm
I have raspbian running correctly but I'm unable to installa wview package on my system, always says It can't find the package.
I've added theses lines to my sources list:
deb http://www.wviewweather.com/apt/wheezy wheezy main
deb-src http://www.wviewweather.com/apt/wheezy wheezy main
When I update It says that its impossible to obtain:
http://www.wviewweather.com/apt/wheezy/ ... f/Packages 404 Not Found
If I explore the route from www.wviewweather.com/... the folder binary-armhf doesn't exists, there is a folder called binary-arml
When I try to apt-get install wview system says the package doesn't exists...
Can anyone help me please? I'm stuck at the first step of using this weather station software...
Thanks a lot!
by Darth » Sat Aug 04, 2012 10:39 am
Exactly the same problem my end. Followed the instructions to install from the wview site and then ran apt-get update:
root@raspberrypi:/home/pi# apt-get update
Hit http://archive.raspberrypi.org wheezy InRelease
Get:1 http://mirrordirector.raspbian.org wheezy InRelease [12.5 kB]
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Get:2 http://backports.debian.org squeeze-backports InRelease [78.5 kB]
Get:3 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,296 kB]
Ign http://www.wviewweather.com wheezy InRelease
Ign http://http.debian.net squeeze InRelease
Ign http://www.wviewweather.com wheezy Release.gpg
Get:4 http://http.debian.net wheezy InRelease [199 kB]
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Hit http://www.wviewweather.com wheezy Release
Hit http://www.wviewweather.com wheezy/main Sources
Ign http://backports.debian.org squeeze-backports InRelease
Ign http://http.debian.net wheezy InRelease
Err http://www.wviewweather.com wheezy/main armhf Packages
404 Not Found
Get:5 http://http.debian.net squeeze Release.gpg [1,672 B]
Err http://backports.debian.org squeeze-backports/main armhf Packages
404 Not Found [IP: 206.12.19.9 80]
Ign http://www.wviewweather.com wheezy/main Translation-en_GB
Err http://backports.debian.org squeeze-backports/contrib armhf Packages
Err http://backports.debian.org squeeze-backports/non-free armhf Packages
Ign http://backports.debian.org squeeze-backports/contrib Translation-en_GB
Ign http://backports.debian.org squeeze-backports/main Translation-en_GB
Ign http://backports.debian.org squeeze-backports/non-free Translation-en_GB
Get:6 http://http.debian.net wheezy/main armhf Packages [5,802 kB]
Get:7 http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [22.6 kB]
Get:8 http://mirrordirector.raspbian.org wheezy/non-free armhf
Packages [46.5 kB]
Get:9 http://http.debian.net wheezy/contrib armhf Packages [35.3 kB]
Get:10 http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [14 B]
Get:11 http://http.debian.net wheezy/non-free armhf Packages [55.6 kB]
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Get:12 http://http.debian.net wheezy/contrib Translation-en [35.6 kB]
Get:13 http://http.debian.net wheezy/main Translation-en [3,926 kB]
Get:14 http://http.debian.net wheezy/non-free Translation-en [66.1 kB]
Hit http://http.debian.net squeeze Release
Ign http://http.debian.net squeeze Release
Ign http://http.debian.net wheezy/contrib Translation-en_GB
Ign http://http.debian.net wheezy/main Translation-en_GB
Ign http://http.debian.net wheezy/non-free Translation-en_GB
Ign http://http.debian.net squeeze/contrib Translation-en_GB
Ign http://http.debian.net squeeze/main Translation-en_GB
Err http://http.debian.net squeeze/main armhf Packages
404 Not Found
Err http://http.debian.net squeeze/contrib armhf Packages
404 Not Found
Err http://http.debian.net squeeze/non-free armhf Packages
404 Not Found [IP: 81.91.108.244 80]
Ign http://http.debian.net squeeze/non-free Translation-en_GB
Fetched 17.6 MB in 2min 38s (111 kB/s)
W: GPG error: http://backports.debian.org squeeze-backports InRelease:
The following signatures couldn't be verified because the public key
is not available: NO_PUBKEY AED4B06F473041FA
W: GPG error: http://http.debian.net wheezy InRelease: The following
signatures couldn't be verified because the public key is not
W: GPG error: http://http.debian.net squeeze Release: The following
W: Failed to fetch
404 Not Found
W: Failed to fetch
http://backports.debian.org/debian-back ... f/Packages
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
http://http.debian.net/debian/dists/squ ... f/Packages
404 Not Found
W: Failed to fetch
404 Not Found
W: Failed to fetch
E: Some index files failed to download. They have been ignored, or old
ones used instead.
Some errors occurred during the update, but I ignored them and then went on to try and install wview with apt-get install wview:
root@raspberrypi:/home/pi# apt-get install wview
Reading package lists... Done
Building dependency tree
E: Unable to locate package wview
Now stuck! I'm a complete noob when it comes to Linux, but trust me, I'm enjoying playing with my 2xPis. I'm now onto my 7th re-install of the base system, I'm learning every time!
Intention is to use a Pi as my primary PC to service my weather station onto Wunderground and the other to sit down with my son and just play around with it.
Any help in being able to install wview would be greatly appreciated.
Darth
by damefrikis » Tue Aug 07, 2012 11:28 am
Hi Darth,
In this link they have created a distro image just to flash on a 16gb sdcard with wview running:
http://forum.meteoclimatic.net/index.ph ... ic=11032.0
Forum is in spanish, maybe should use google translator.
See you
by jantoni » Wed Aug 08, 2012 4:46 pm
Hi, i made the image not to raspbian and thinking only in wview.
The link to download is:
https://dl.dropbox.com/u/70131852/Image ... 0Wview.rar
Remarks:
- The image is from Debian Squeeze (19-4-2012)
- SSH enabled
- Wview 5.20.2 installed and tested in simulation mode
- The image size is 16GB. Yes, you can resize it.
- Modified script /etc/init.d/wview due init errors after a power failure.
- Time Zone is UTC. Use "dpkg-reconfigure tzdata" to change it.
- Swap partition is enabled
- Two users active:
user: pi password: raspberry
user: root password: root (is not original, but i hate sudo command)
You must to do:
Y ¿que tiene que hacer el usuario?
- Wview configuration. Please, read the manual, Wview is easy to configurate and understand.
- Tune your Rasp. Delete servers and services you don't use.
- Change the root password. You can delete "root" user too.
- Add other users.
- Update Debian. Debian Squeeze is updated until 7-7-2012
- Change SSH Keys:
rm /etc/ssh/ssh_host*
dpkg-reconfigure openssh-server
- Edit /etc/hostname and /etc/hosts
Thanks for your interest....and remember.....IS NOT RASPBIAN.
Regards from jantoni-EA4DQX
by jpedrodias » Sun Aug 12, 2012 7:13 pm
See how to install (compile) wview on Raspbian or download Raspbian with wview installed
by Darth » Sun Aug 12, 2012 7:17 pm
jpedrodias wrote:See how to install (compile) wview on Raspbian or download Raspbian with wview installed
He he - I have Pedro - fully installed and working as mentioned over on the Google WVIEW forum!
Dave
