Shell In A Box
by ruswetherell » Wed Jun 27, 2012 10:11 am
Has anyone tried to implement 'shellinabox' on their Pi. http://code.google.com/p/shellinabox/
I am looking for a way to remote into my Pi using some form of web-based SSH client, but don't trust any web based services with my ssh credentials. That's quite some keys you are handing over there.
It would be very handy if you are not on a machine with a good terminal app / Putty or allowed to install one by company IT, are filtered to not having port 22 available, or other uses such as a good web based shell to use while on the ChromeOS notebook let's say.
Here is a guide i found which shows how to setup and install shellinabox on Ubuntu or Debian over a secure port (standard HTTPS 443) and also require a login prompt to first get to the shellinabox interface as a layer of security.
http://scottlinux.com/2010/12/15/shelli ... https-443/
I haven't tried it yet, as I can't remote in from work ;)
Many thanks,
by ruswetherell » Wed Jun 27, 2012 9:23 pm
So if any one is interested, I tried downloading the latest deb from the project page http://code.google.com/p/shellinabox/downloads/list:
And installing with:
sudo dpkg -i shellinabox_2.10-1_armel.deb
And got:
Selecting previously unselected package shellinabox.
(Reading database ... 61929 files and directories currently installed.)
Unpacking shellinabox (from shellinabox_2.10-1_armel.deb) ...
dpkg: dependency problems prevent configuration of shellinabox:
shellinabox depends on libssl0.9.8 (>= 0.9.8f-5); however:
Package libssl0.9.8 is not installed.
dpkg: error processing shellinabox (--install):
dependency problems - leaving unconfigured
Processing triggers for man-db ...
shellinabox
So then I tried:
sudo apt-get install shellinabox
And got:
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
shellinabox
1 upgraded, 0 newly installed, 0 to remove and 102 not upgraded.
1 not fully installed or removed.
Need to get 134 kB of archives.
After this operation, 44.0 kB of additional disk space will be used.
Get:1 http://http.debian.net/debian/ wheezy/main shellinabox armel 2.14-1 [134 kB]
Fetched 134 kB in 0s (146 kB/s)
dpkg: error processing shellinabox (--configure):
shellinabox
E: Sub-process /usr/bin/dpkg returned an error code (1)
So then I tried a:
sudo apt-get install libssl0.9.8
And got a:
Package libssl0.9.8 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libssl0.9.8' has no installation candidate
Does any one know how to install this libssl0.9.8 package?
A quick google returns comments like:
libssl and libcrypto shared libraries needed by programs like apache-ssl, telnet-ssl and openssh.
It is part of the OpenSSL implementation of SSL.
Many thanks....
by IsSuE » Fri Jun 29, 2012 8:34 am
apt-get install openssl
should install you libssl.so
by rubusrubus » Tue Jan 22, 2013 9:17 pm
Hi, bit of an old posting but I found it googling and see no one answered. This evening I made quite some progress by downloading and compiling on the PI itself . Follow the instructions here:
http://www.linux-mag.com/id/7864/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+LinuxMagazine+%28Linux+Magazine%3A+Top+Stories%29
the last command needs to be run as root so the exact sequence is:
./configure
make
sudo make install
Then run it with shellinaboxd (don't forget the d on the end)
On your windows pc it's then just a case of goign to the URL http://<IP-of-pi>:4200 See the results in firefox here:
No time now to mess with other options like https etc, but it is defnately possible!
by RTL » Thu Jan 24, 2013 1:43 am
You can also use the Web Shell plugin for BarracudaDrive:
viewtopic.php?p=268362#p268362
