Option 1 - Download
Download the package I compiled on a Pi earlier tonight:
- Code: Select all
wget http://dl.dropbox.com/u/87792204/nginx_1.2.1-1~squeeze_armel.deb
- Code: Select all
md5sum nginx_1.2.1-1~squeeze_armel.deb
3284746b2470bea853c8c590072e4b52 nginx_1.2.1-1~squeeze_armel.deb
- Code: Select all
sudo dpkg -i nginx_1.2.1-1~squeeze_armel.deb
Compile your own version the way I did:
Edit package sources:
- Code: Select all
sudo nano /etc/apt/sources.list
- Code: Select all
deb http://nginx.org/packages/debian/ squeeze nginx
deb-src http://nginx.org/packages/debian/ squeeze nginx
- Code: Select all
- Code: Select all
mkdir nginx_src
cd nginx_src
- Code: Select all
sudo apt-get update
sudo apt-get upgrade
sudo apt-get -y install build-essential debhelper libpcre3-dev
sudo apt-get -b source nginx
- Code: Select all
