Bandwidth Monitor (vnstat)
by Ogoshi » Sun Jun 03, 2012 4:14 pm
I've found vnstat to be useful for monitoring bandwidth on Raspbmc (although it would work fine on Debian squeeze too)
Link here - http://www.debian-administration.org/articles/330
To install type - sudo apt-get install vnstat
Then to start it type - sudo vnstat -u -i eth0
I found that it wasn't updating the database automatically (i guess this may be a permission issue, beyond my beginner linux knowledge!) to get round this, when you want to view the stats type - sudo vnstat --update
Then just type - vnstat
to view.
You can also do vnstat --live to well erm see the activity live...
There are a variety of commands in the help page too.
Apologies if any of that is incorrect or useless, I'm a linux beginner and typing on my phone - typos highly likely!
I found this quite useful while live streaming with tvcatchup
Note: this will count all traffic to/from the pi regardless of wan/lan!
Gary
by linorics » Sun Jun 24, 2012 7:42 pm
Thanks for the tool I'll have to check it out.
One thing to note is that Linux keeps track of this in a file as well.
cat /proc/net/dev
This will return the counter of all of the traffic passing through off of the interfaces.
Inter-|   Receive                                                |  Transmit
 face |bytes    packets errs drop fifo frame compressed multicast|bytes    packets errs drop fifo colls carrier compressed
    lo:     560       8    0    0    0     0          0         0      560       8    0    0    0     0       0          0
  eth0: 36911726  587879    0    0    0     0          0         0  1043482   10340    0    0    0     0       0          0
It makes for a fun coding project to extract the right field and the the bandwidth.
