Django on the Raspberry pi
by phalt » Fri Jun 01, 2012 2:56 pm
I've successfully got Django installed and running on my raspberry pi.
I am now tempted to create a script for automatically installing the required packages for anyone who wants to install Django themselves.
I have searched online but I haven't found anything like this yet.
Would this be useful for people, especially beginners?
by unepic » Sat Jun 02, 2012 7:41 am
Yes!
I'd like to try Django on the Raspberry pi.
Looking forward to it.
by olibanum » Wed Jun 06, 2012 9:13 pm
Definitely interested. I was about to make a start myself but any head start I can get the better! Thank you.
by phalt » Thu Jun 07, 2012 12:39 pm
Sorry for the slow reply, with the 4 day weekend we've just had I've been busy relaxing and travelling :)
I've written a script that runs awesomely on my linux desktop, just need to get it onto a pi and test it now.
I'll be making it for the Debian release first, as it is the one I'm most familiar with. Should have it ready in a few days!
Blog post and instructions will be included.
by phalt » Wed Jun 13, 2012 7:31 pm
Hey guys. I've successfully created a simple script that will install django on the raspberry pi.
This is aimed at people who are not used to heavy installation and it automates 100% of the process. It also downloads a few extra bits for django and you can add your own packages in requirements.txt if you wish:
The github repo is at:
https://github.com/phalt/DjangoPi
and I had no problems installing git and fetching it on my pi.
I'd really like some feedback on improvements or any bugs you encounter.
Enjoy!
by olibanum » Wed Jun 13, 2012 7:40 pm
Cracking thanks! Ill take a look as soon as ive got the latest firmware and my wireless dongle working again after the previous update killed it.
by lightnin » Wed Jun 20, 2012 5:01 pm
Thanks for making the script! I recently gave it a go and it seemed to work quite well.
One thing I'm not sure about, that would be helpful to touch on in the documentation, is how to get Django to display your site via apache (rather than simply using the runserver command.)
It appears as though there are some additional steps required.
Also - might it not be better to use sqlite and / or lightpd (or maybe nginx) - as they are a bit more light weight?
Probably your major criteria should be ease of use, if you hope to make it easy for lots of people to setup webservers on their pis. Perhaps that's another reason to use a different webserver.
by ceefan » Thu Jun 21, 2012 9:02 pm
Here's the sqlite/nginx version I made for my own benefit:
http://www.raspberrypi.org/phpBB3/viewtopic.php?p=105768#p105768
by phalt » Mon Jun 25, 2012 8:51 am
Awesome nice work! I'm currently starting a bigger project related to this, I'll post news about it once I get it up and running, but it will encompass most django setups for raspberry pi.
by chrissowa » Mon Jun 25, 2012 10:58 am
Anything speaking against using the bitnami stacks?
http://bitnami.org/stack/djangostack
by NickT » Mon Jul 02, 2012 4:15 pm
Excellent script, works well on standard Squeeze Debian. Mysql seems to work well too. Well done and thanks.
by phalt » Tue Jul 03, 2012 3:20 pm
NickT wrote:Excellent script, works well on standard Squeeze Debian. Mysql seems to work well too. Well done and thanks.
Glad it worked well! I added virtualenv support to it earlier this week.
This is also now being incorporated into a larger project - a full stack educational website running on a raspberry pi that teaches you to run a website on a raspberry pi (recursion!)
If you're interested:
https://sponsorcraft.com/p/djangopi
by guillemhs » Sat Aug 18, 2012 8:38 pm
Bitnami stacks are not ready to Raspberry Pi.
These stacks are 100% x86-based.
Not compatible with ARM.
I asked that on the forums here
http://answers.bitnami.org/questions/67 ... spberry-pi
by phalt » Thu Aug 23, 2012 10:17 pm
I've started to use nginx as well after getting much better performance. Will update to accomodate it.
by granra » Sat Aug 25, 2012 2:04 pm
I just tried this on a fresh Raspbian setup and I get this.
./setup.sh: line 46: ../bin/activate: No such file or directory
Now we're going to install django and any other packages
./setup.sh: line 49: ../bin/pip: No such file or directory
Finally, lets make sure Django is installed properly - this will print the version number if successful
File "djangotest.py", line 1, in <module>
import django
ImportError: No module named django
./setup.sh: line 54: deactivate: command not found
Done!
by cloud1771 » Thu Mar 07, 2013 2:32 am
I his this issue, When i downloaded it I installed unzipped in in /home/pi/djangopi and there is a line in the setup.sh that looks like its looking for it at /djangopi
I changed that path and it seems to have finished the install compleately
by cloud1771 » Thu Mar 07, 2013 2:34 am
My only issue is I ran the script at github, and i not get the Welcome to nginx! page when i goto my IP.
Am i missing a step? how do I get to where I can update/make changes to my server.
Matt
by dliloch » Thu Mar 07, 2013 11:00 pm
hello,
I am having troubles getting the product to install.
I am running at the following level
root@raspberrypi4:~# uname -a
Linux raspberrypi4 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l GNU/Linux
I have these files in my /root directory
root@raspberrypi4:~# ls -al
total 48
drwx------ 6 root root 4096 Mar 7 17:46 .
drwxr-xr-x 25 root root 4096 Mar 7 17:47 ..
-rw------- 1 root root 156 Mar 7 17:14 .bash_history
-rw-r--r-- 1 root root 570 Jan 31 2010 .bashrc
drwx------ 6 root root 4096 Oct 27 20:16 .config
-rwxr-xr-x 1 root root 112 Mar 7 17:44 djangotest.py
drwx------ 2 root root 4096 Mar 7 16:42 .netsurf
-rw-r--r-- 1 root root 140 Nov 19 2007 .profile
drwxr-xr-x 5 root root 4096 Oct 25 14:20 .rpi-firmware
-rwxr-xr-x 1 root root 1586 Mar 7 17:45 setup.sh
drwx------ 4 root root 4096 Oct 24 07:34 .thumbnails
-rw------- 1 root root 2873 Nov 2 21:16 .viminfo
here is what happens when I type ./setup.shroot@raspberrypi4:~# ./setup.sh
Updating all existing packages...
Hit http://mirrordirector.raspbian.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Reading package lists... Done
Installing some essential stuff...
Installing python essentials
Building dependency tree
python-virtualenv is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
python-pip is already the newest version.
Installing nginx server...
openssh-server is already the newest version.
nginx is already the newest version.
The --no-site-packages flag is deprecated; it is now the default behavior.
New python executable in ./bin/python
ERROR: The executable ./bin/python is not functioning
ERROR: It thinks sys.prefix is u'/usr' (should be u'/')
ERROR: virtualenv is not compatible with this system or executable
Requirement already satisfied (use --upgrade to upgrade): django-fab-deploy in /usr/local/lib/python2.7/dist-packages
Cleaning up...
build-essential is already the newest version.
python-dev is already the newest version.
./setup.sh: line 45: cd: DjangoPi/: No such file or directory
python: can't open file 'djangotest.py': [Errno 2] No such file or directory
Done!
Any suggestions would be greatly appreciated.. thanks..
by bavovna » Thu May 09, 2013 7:46 pm
I have exactly the same problem. I tried to run ./install.sh under root.
0 upgraded, 0 newly installed, 0 to remove and 156 not upgraded.
Done!
