The idea is to use the standard windows 7 ipsec vpn client tools to connect to the gateway.
Does anyone has experience with this?
I am stuck
Best regards
Killerbee
nicknml wrote:I personally would rather use openvpn as it's easier to setup.
honda4life wrote:Can you be more specific about how to adapting the kernel please (modules)
make ARCH=arm CROSS_COMPILE=/usr/bin/arm-linux-gnueabi- menuconfigDevice drivers -->
Network device support -->
[M] PPP MPPE Compression (encryption)
make ARCH=arm CROSS_COMPILE=/usr/bin/arm-linux-gnueabi- -kJul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: local address = 192.168.1.4
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: remote address = 192.168.0.234
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: pppd options file = /etc/ppp/pptpd-options
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Received PPTP Control Message (type: 1)
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Made a START CTRL CONN RPLY packet
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: I wrote 156 bytes to the client.
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Sent packet to client
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Received PPTP Control Message (type: 7)
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Set parameters to 100000000 maxbps, 64 window size
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Made a OUT CALL RPLY packet
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: pty_fd = 6
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: tty_fd = 7
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: I wrote 32 bytes to the client.
Jul 10 22:31:11 raspberrypi pptpd[2112]: CTRL (PPPD Launcher): program binary = /usr/sbin/pppd
Jul 10 22:31:11 raspberrypi pptpd[2112]: CTRL (PPPD Launcher): local address = 192.168.1.4
Jul 10 22:31:11 raspberrypi pptpd[2112]: CTRL (PPPD Launcher): remote address = 192.168.0.234
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Received PPTP Control Message (type: 15)
Jul 10 22:31:11 raspberrypi pptpd[2110]: CTRL: Got a SET LINK INFO packet with standard ACCMs
Jul 10 22:31:11 raspberrypi pptpd[2110]: GRE: accepting packet #0
Jul 10 22:31:12 raspberrypi pptpd[2110]: CTRL: Reaping child PPP[2112]
Jul 10 22:31:12 raspberrypi pptpd[2110]: CTRL: Exiting now
Jul 10 22:31:12 raspberrypi pptpd[788]: MGR: Reaped child 2110
