Power USB wireless dongles
by muad_dib » Tue Oct 30, 2012 1:05 am
I read that Raspberry PI is capable of powering 100 mA per port, while most dongles use much more than that.
I also read that many use wifi dongles without problems.
How's that possible? Everyone using external powered USB host?
by SirLagz » Tue Oct 30, 2012 4:40 am
The newer Raspberry Pis don't have that limitation anymore.
The older ones did due to the polyfuses
Visit my blog for ffmpeg Webcam streaming, Raspbian Server Edition, RaspAP Hotspot guides and more !
Home of PiParted - A custom GParted LiveCD to make installing OSes onto the SD Card easier !!
by rew » Tue Oct 30, 2012 4:17 pm
Plus, the cheap dongles do NOT use more than 100mA and work just fine on an unmodified 'pi V1.
Check out our raspberry pi addons: http://www.bitwizard.nl/catalog/
by Durazell » Sun Nov 04, 2012 9:07 am
SirLagz wrote:The newer Raspberry Pis don't have that limitation anymore.
Do you mean usb can output more than 100mA? I tried to connect samsung galaxy s III through usb, and it wasn't recognized at all (tailing and lsusb did not react at all)
EDIT: I'm using model B with 512mb RAM, with 1,2A 5V power supply (Nokia N900 charger)
by SirLagz » Mon Nov 05, 2012 2:44 am
Did the phone start charging ?
Was the phone in debug mode ?
Have you activated the 'disk drive' mode of the phone ?
by Durazell » Thu Nov 08, 2012 2:33 pm
SirLagz wrote:Did the phone start charging ?
It was android phone. Phone didn't start to charge (although at first connect charging led flashed once) and i couldnt choose any of the modes because device was not recognized.
