OpenELEC Testbuilds
766 posts   Page 20 of 31   1 ... 17, 18, 19, 20, 21, 22, 23 ... 31
by rick19011 » Fri Aug 03, 2012 9:40 pm
HDMI CEC automatically disconnects when changing hdmi resolution, how do I fix this because I want 1080p 24HZ resolution/refresh rate but I can't press ok when I change it as my remote stops working...
by dom » Sat Aug 04, 2012 10:56 am
rick19011 wrote:HDMI CEC automatically disconnects when changing hdmi resolution, how do I fix this because I want 1080p 24HZ resolution/refresh rate but I can't press ok when I change it as my remote stops working...
viewtopic.php?f=35&t=7167&start=450#p136505
Moderator
by ZZ600E3 » Sat Aug 04, 2012 11:05 pm
I have an issue that I posted elsewhere regarding CEC that could kind of tie in to this. Basically after using OpenElec on my setup which is a Sony DA2400ES AV receiver and Bravia model 52W4000 TV, the link between those two devices becomes broken and only a factory reset on the TV will allow them to see each other again and sync. I do not have OpenElec setup to take advantage of CEC as far as I know but it breaks the link between other devices anyhow when used to watch movies etc.
I'll give the disable refresh rate a go tomorrow but is it really capable of completely handicapping the link between all devices as I'm experiencing or has anyone else come across my exact dilemma that can give me some pointers as to how to fix it?
by dom » Sun Aug 05, 2012 3:40 pm
dom wrote:Yes, changing hdmi mode does stop CEC working. Disable "sync display to video frame rate" and it will continue working. It's being investigated.
A potential fix has been pushed to github. You can download start.elf from github or wait for an updated official build.
This start.elf also tries to avoid killing composite when (incorrectly) starting CEC or HDMI audio.
Moderator
by sraue » Tue Aug 07, 2012 1:15 am
Another short update (r11766):
http://sources.openelec.tv/tmp/image/op ... 66.tar.bz2
to update a older build without reinstalling see: http://wiki.openelec.tv/index.php?title ... g_OpenELEC
  • updated XBMC many thanks to 'gimli' and the whole XBMC dev team
  • added bootloader update support many thanks to ME :-)
    for this update it is still needed to update the bootloaderfiles manually, because the bootloader update support must be in the actual running build. With the next update it will work automatically.
  • Kernel linux 3.2.26 many thanks to 'bootc'
  • added libcofi https://github.com/simonjhall/copies-and-fills many thanks to 'simonjhall'
  • various other improvenments, fixes and package updates
It is needed to update the bootloaderfiles which you can find in the build in the folder 3rdparty/bootloader to fix reported problems with libCEC, composite output and HDMI audio passthrough. This you can update locally via Windows/Linux or via ssh:
  • login via ssh to your Raspi:
    ssh root@<ipaddress>
  • remount /flash r/w:
    mount -o remount,rw /flash
  • from your linux system copy the files via ssh/scp to the Raspi:
    scp 3rdparty/bootloader/* root@<ipaddress>:/flash
please test this build, the CEC function with various TV's and XBMC in general and report back.
thanks
Stephan
by cpswan » Tue Aug 07, 2012 7:23 am
sraue wrote:Another short update (r11766):
For anybody wanting a canned image of r11766 that will fit onto 1GB SD (or larger).
by sparky0815 » Tue Aug 07, 2012 9:21 am
Fitted images for 1GB / 2GB / 4GB / 8GB / 16GB and 32GB sdcard of r11766 you can find on
http://sparky0815.de/openelec-download-images-fat-files/
have fun :geek:
Twitter: @Sparky0815
Facebook Gruppe: http://on.fb.me/PnYE99
unofficial OpenELEC SD-Card Images: http://bit.ly/MB0YtN
Moderator
by jbruntt » Tue Aug 07, 2012 9:35 am
I would like to know if playback from MythTv v 0.25 is in the current OpenELEC build.
The way I read it over in the xbmc forum - Testing help needed for Myth 0.25 support - v 0.25 playback has been submitted to the xbmc build tree, but has it trickled down into OpenELEC?
Just for backgrund information, I have succesfully had OpenELEC (r11591) playing recordings off a v 0.24 MyTV server. With some pauses though (which i believe have nothing to do with OpenELEC or the rpi).
by Goofy » Tue Aug 07, 2012 6:32 pm
sraue wrote:Hi,
Similar to 11691 it's much more stable for playing music and picture slideshow. It's hard to reproduce, but xbmc freeze ocassionally:( Playing the same set of mp3 works fine sometimes, and sometimes there is a long delay between the songs (even 10s). I noticed that it takes some time to load the pictures even about 8s (they have about 3-5MB). I tried to increase the slideshow
Picture slideshow freezed at the end of:
15:55:30 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4315.JPG
15:55:30 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:55:30 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:55:30 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:55:30 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:55:31 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:55:37 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4315.JPG
15:55:37 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:55:39 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4314.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4315.JPG
15:55:39 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4316.JPG
15:55:39 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:55:39 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:55:39 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:55:39 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:55:39 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:55:40 T:1265210464   ERROR: Previous line repeats 51 times.
15:55:40 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:55:40 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:55:46 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4316.JPG
15:55:46 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:55:48 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4315.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4316.JPG
15:55:48 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4317.JPG
15:55:48 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:55:48 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:55:48 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:55:48 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:55:49 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:55:55 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4317.JPG
15:55:55 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:55:57 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4316.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4317.JPG
15:55:57 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4318.JPG
15:55:57 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:55:57 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:55:57 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:55:57 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:55:58 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:56:05 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4318.JPG
15:56:05 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:56:06 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4317.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4318.JPG
15:56:06 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4319.JPG
15:56:06 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:56:06 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:56:06 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:56:06 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:56:07 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4319.JPG
15:56:07 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:56:11 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4318.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4319.JPG
15:56:11 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4320.JPG
15:56:11 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:56:11 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:56:11 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:56:11 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:56:12 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:56:18 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4320.JPG
15:56:18 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:56:19 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4319.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4320.JPG
15:56:19 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4321.JPG
15:56:20 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:56:20 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:56:20 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:56:20 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:56:20 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:56:21 T:1265210464   ERROR: Previous line repeats 50 times.
15:56:21 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:56:21 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:56:27 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4321.JPG
15:56:27 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:56:27 T:1075188496   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/libexif-arm.so)
15:56:27 T:1075188496   DEBUG: Unloading: libexif-arm.so
15:56:28 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4320.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4321.JPG
15:56:28 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4322.JPG
15:56:29 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:56:29 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:56:29 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:56:29 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:56:30 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:56:36 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4322.JPG
15:56:36 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:56:37 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4321.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4322.JPG
15:56:37 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4323.JPG
15:56:38 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:56:38 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:56:38 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:56:38 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:56:38 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:56:39 T:1265210464   ERROR: Previous line repeats 50 times.
15:56:39 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:56:39 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
After pressing X on keyboard log says it switched to the new picutre, but nothing happened on the screen, it freezed completely including ssh session:
16:22:05 T:1075188496   DEBUG: Keyboard: scancode: 2d, sym: 0078, unicode: 0078, modifier: 0
16:22:05 T:1075188496   DEBUG: OnKey: x (f058) pressed, action is Stop
16:22:05 T:1075188496   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
16:22:05 T:1075188496   DEBUG: Waiting for BackgroundLoader thread to close
15:54:22 T:1075188496   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
15:54:22 T:1075188496   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
15:54:23 T:1075188496   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
15:54:24 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4305.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4306.JPG
15:54:24 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4307.JPG
15:54:24 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:54:24 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:54:24 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:54:24 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:54:24 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:54:25 T:1183839328   ERROR: Previous line repeats 27 times.
15:54:25 T:1157309536   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
15:54:25 T:1140106336   ERROR: Previous line repeats 3 times.
15:54:25 T:1140106336   ERROR: Previous line repeats 4 times.
15:54:25 T:1265210464   ERROR: Previous line repeats 13 times.
15:54:25 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:54:32 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4307.JPG
15:54:32 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:54:33 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4306.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4307.JPG
15:54:33 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4308.JPG
15:54:33 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:54:33 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:54:33 T:1265210464   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
15:54:33 T:1265210464   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
15:54:34 T:1265210464   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
15:54:41 T:1265210464   DEBUG: Finished background loading /storage/pictures/testset/SAM_4308.JPG
15:54:41 T:1265210464   DEBUG: Duration: 360 (transistion out length 60)
15:54:42 T:1075188496   DEBUG: Image /storage/pictures/testset/SAM_4307.JPG is finished rendering, switching to /storage/pictures/testset/SAM_4308.JPG
15:54:42 T:1075188496   DEBUG: Loading the next image /storage/pictures/testset/SAM_4309.JPG
15:54:43 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
15:54:43 T:1265210464   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
15:54:43 T:1265210464   DEBUG: COMXCoreComponent::AllocInputB
by milhouse » Tue Aug 07, 2012 6:38 pm
Just as a test (for comparison with Raspbmc RC4) after installing r11766 I wiped my Texture13.db and Thumbnails directory, rebooted then attempted to browse through Movies while it recached all the thumbnails - unfortunately there are a mass of errors and failure to display images (black rectangles) within just the first few rows after scrolling (the following is just the log grep'ed for ERROR):
19:35:35 T:1299588192   ERROR: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - OMX_UseBuffer failed with omx_err(0x80001000)
19:35:35 T:1299588192   ERROR: COMXImage::Decode m_omx_resize.AllocOutputBuffers result(0x80001000)
19:35:35 T:1299588192   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000000 timeout 300
19:35:35 T:1299588192   ERROR: COMXCoreComponent::SetStateForComponent - OMX.broadcom.resize failed with omx_err(0x80001000)
19:35:35 T:1156142176   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.resize - OMX_ErrorInsufficientResources, insufficient resources
19:35:36 T:1211585632   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000004 timeout 1000
19:35:36 T:1211585632   ERROR: COMXImage::Decode m_omx_decoder.WaitForEvent result(0x7fffffff)
19:35:36 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:36 T:1228362848   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:35:38 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:35:38 T:1228362848   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:35:39 T:1299588192   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:39 T:1299588192   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:35:40 T:1299588192   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:35:40 T:1299588192   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:35:41 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:41 T:1211585632   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:35:41 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:41 T:1228362848   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:35:52 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:35:52 T:1318057056   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:35:53 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:53 T:1318057056   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:35:53 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:35:53 T:1211585632   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:35:53 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:35:53 T:1228362848   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:35:56 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:35:56 T:1318057056   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:35:57 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:57 T:1211585632   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:35:58 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:35:58 T:1228362848   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:00 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:36:00 T:1228362848   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:36:02 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:02 T:1318057056   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:03 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:36:03 T:1211585632   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:36:05 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:05 T:1318057056   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:06 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:06 T:1228362848   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:06 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:06 T:1211585632   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:07 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:36:07 T:1318057056   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:36:08 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:36:08 T:1211585632   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:36:08 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_decode omx_err(0x80001000)
19:36:08 T:1228362848   ERROR: COMXImage::Decode error m_omx_decoder.Initialize
19:36:12 T:1318057056   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:12 T:1318057056   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:12 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:12 T:1228362848   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:12 T:1211585632   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
19:36:12 T:1211585632   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
19:36:14 T:1211585632   ERROR: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - OMX_UseBuffer failed with omx_err(0x80001000)
19:36:14 T:1211585632   ERROR: COMXImage::Decode m_omx_resize.AllocOutputBuffers result(0x80001000)
19:36:14 T:1228362848   ERROR: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - OMX_UseBuffer failed with omx_err(0x80001000)
19:36:14 T:1228362848   ERROR: COMXImage::Decode m_omx_resize.AllocOutputBuffers result(0x80001000)
19:36:14 T:1211585632   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000000 timeout 300
19:36:14 T:1211585632   ERROR: COMXCoreComponent::SetStateForComponent - OMX.broadcom.resize failed with omx_err(0x80001000)
19:36:14 T:1228362848   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000000 timeout 300
19:36:14 T:1228362848   ERROR: COMXCoreComponent::SetStateForComponent - OMX.broadcom.resize failed with omx_err(0x80001000)
19:36:18 T:1156142176   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.resize - OMX_ErrorInsufficientResources, insufficient resources
19:36:19 T:1318057056   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000004 timeout 1000
19:36:19 T:1318057056   ERROR: COMXImage::Decode m_omx_decoder.WaitForEvent result(0x7fffffff)
19:36:19 T:1228362848   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
etc. etc.
Until these OMX issues are knocked on the head I can't see any version of XBMC on R-Pi being ready for prime time. :(
by Doktor-X » Tue Aug 07, 2012 7:46 pm
i must say that i'm finaly suprise with Stability and speed of corrent openelec build 11766 although cec is not working on my LG ld450 speed of loading fanart and poster is extreamly fast :D mkv with dts audio play's without stuttering :o this is it ;)
by AceX » Wed Aug 08, 2012 9:32 am
hi, I have a problem that can not I create a random playlist of videos. What's the solution?
by ipsection » Wed Aug 08, 2012 1:09 pm
by sparky0815 » Tue Aug 07, 2012 5:21 am
http://sparky0815.de/openelec-download- ... fat-files/
sparky0815 - can I update from a previous build to r11766 by just updating the FAT files, or do I need to get new image?
and do I update the FAT file by just overwriting them on the SD card - or do I follow this procedure - http://wiki.openelec.tv/index.php?title ... g_OpenELEC
by DJ_Datte » Wed Aug 08, 2012 1:43 pm
Hi!
I have a issue with my rpi/openelec. I have a conf file (mainly to force hdmi, and some small stuff like that), and up to a few weeks ago, the rpi has worked flawless. I've updated images from time to time no problem (sometimes having to patch the firmware as well).
But my most recent time, about 2 weeks ago (whichever image was current at the time), after updating, the RPI refused to boot. I thought it was my SD Card that had borked, so I reflashed it in the PC instead of updating openelec, and nothing, completly dead.
I tried to remove my conf file, and it worked fine again.
Have some changes been done to the firmware to create this situation, so conf files won't let the rpi boot ?
Thank you kindly
by milhouse » Wed Aug 08, 2012 2:17 pm
ipsection wrote:sparky0815 - can I update from a previous build to r11766 by just updating the FAT files, or do I need to get new image?
Yes, that's all you need to update with OpenELEC - the entire system lives in the FAT partition. Just download the small bz2 image linked by sraue, extract the various files (7zip is good for this, the three firmware files are in the 3rdparty/bootloader folder, the two OpenELEC files - ignore the MD5 checksum files - are in the target folder, remember to rename KERNEL to kernel.img) and then overwrite the same files in your SD card.
by IvanG » Wed Aug 08, 2012 4:13 pm
Hi all
I just tried updating to from 11691 to 11766, and can't boot anymore
I get only:
OpenELEC-RPi.arm-devel-20120807030154-r11766
udevadm settle - timeout of 120 seconds reached, the even queue contains:
/sys/devices/platform/bcm2708_usb1/1-1/1-1.1/1-1.1:1.0/ent/eth0 (752)
/sys/devices/platform/bcm2708_usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0 (755)
/sys/devices/platform/bcm2708_usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0/input0 (756)
/sys/devices/platform/bcm2708_usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0/input0/event0 (757)
/sys/devices/platform/bcm2708_AUDIO.0/sound/card0/controlIC0 (763)
/sys/devices/virtual/block/loop0 (819)
/sys/devices/platform/bcm2708_AUDIO.0/sound/card0 (957)
the only "odd" thing I'm doing is using neboot/nfs for system and storage for system.
But i did this for earlier versions and it did worked just fine...
I just tried downloading 11764 and same timeout happens so I reverted to 11691 and system is up and running again. Not sure what changed between 11691 and 11764 but it seems netboot is broken for some reason.
by AceX » Wed Aug 08, 2012 7:29 pm
The Party mode (videos) is not work!
If turn on after automatically turn off flag.
by ZZ600E3 » Thu Aug 09, 2012 7:08 am
The cec connection and set up is better but still plagued with issues on my setup.
How come there is no option to select the type of device its plugged in to? It behaves like the tv is first in the loop although it's actually an av receiver.
This still keeps breaking the cec link between my tv and av receiver, only resolve is to unplug the pi and factory reset the tv for it to 'see' any hdmi devices to control....... But then again, I don't even need to have power to the pi for this issue to occur, just plugging in an hdmi cable wreaks havok so software may be perfect but the pi isn't :'(
by AceX » Thu Aug 09, 2012 8:15 pm
Hi again,
guisettings.xml contains a line
<myvideos>
<playlist>
<shuffle>false</shuffle>
This is option important to me, but i can't find option the settings menu.
If i change the file then soon returns false automatically.
What can be done?
by milhouse » Thu Aug 09, 2012 8:23 pm
AceX wrote:Hi again,
<myvideos>
<playlist>
What can be done?
You probably want to edit guisettings.xml when XBMC is not running, otherwise it has a tendency to overwrite your change with it's running values. I think there's a way to kill XBMC and prevent it from automatically restarting, mentioned either in this thread or the other loooong OpenELEC thread.
by AceX » Fri Aug 10, 2012 4:43 am
<myvideos>
<playlist>
What can be done?
Thanks for the tip,
Have been solved that option fix true. (Vi edit the guisettings.xml and killal -9 xbmc.bin and restart...)
Unfortunately The problem is not resolved. Play the tracks on a continuous.
This is a bug! I think.
by JoeDaStudd » Fri Aug 10, 2012 8:28 am
According to this post on the OpenELEC forums they added more wireless adapter support.
As my internet at home is still off I haven't had chance to test any of the latest images. Can anyone confirm the post was correct that that builds after the 8th of August 2012 have built in support for Realtek RTL8188CUS based devices?
Thanks,
Joe
by ChrisLaurie » Fri Aug 10, 2012 12:52 pm
I am testing with r11785. I use the slideshow as screensaver and after a while 15min or so, it just freezes the pi completely.
by milhouse » Fri Aug 10, 2012 1:22 pm
ChrisLaurie wrote:I am testing with r11785. I use the slideshow as screensaver and after a while 15min or so, it just freezes the pi completely.
Is ssh still working? Post your logs, preferably with debug enabled.
by ChrisLaurie » Fri Aug 10, 2012 3:22 pm
I ran in debug mode as preview. It ran fine and I thought OK let's try it with some music playing as well. When I hit the keyboard I saw it was frozen. The on-screen debug message has stopped updating and the screen is frozen on the last picture shown.
ssh works as does the samba share (where I got the attached) log files.
log-2012-08-10-15.02.47.zip
(46.61 KiB) Downloaded 24 times
