Hi, I tried openelec on my RPi with the latest build :
http://sources.openelec.tv/tmp/image/op ... 92.tar.bz2
It works with 720p mkv over the local network, but not for all of them. For some mkv, it only displays a black screen with no sound, even if the time bar is progressing correctly.
I tried an another build, but the same problem occurs, with the same files.
How can I fix this ?
OpenELEC meets Raspberry Pi - part 1 (XBMC)
What Player, HDMI Or Composite Video?
On a TV via HDMI (1280x768)
Oyashiro wrote:Hi, I tried openelec on my RPi with the latest build :
MKV is just a container - what video/audio codec didn't play? You can view this information with MediaInfo.
First I've heard of any probs with hdmi! I would try on a 1080P TV. I Can play almost all 1080P On mine Has A Few Probs W/ AC3 Audio(Just A guess). Only 2 movies thus far Of Over 1500 I Have HD. Some Avis i have Give me Trouble too!
does xbmc have a way to manually ssh into the Pi, add network shares over terminal and then see them inside XBMC?
The codec used is H264 for all of them.
Where should the samba.conf file be on the new build? I see a samba.conf.sample? Should i just set parameters & rename samba.conf? Thanks smuggly
Also when i ssh 192. blah blah blah i get a key error warning?
smuggly wrote:Where should the samba.conf file be on the new build? I see a samba.conf.sample? Should i just set parameters & rename samba.conf?
Yes.
Thanks Very Much
smuggly wrote:Also when i ssh 192. blah blah blah i get a key error warning?
The first time you SSH to a new host you'll receive a warning because your local machine doesn't have anything to compare it to.
If the host changes in the future you'll get the warning again. If you expected it to have changed since your last ssh (ie. you just upgraded to a new release) then this is expected. If you haven't changed things then this is a warning of a security issue (ie. man-in-the-middle attack). Not a likely event on your home network.
tl;dr answer 'yes' to accepting the fingerprint on your first ssh visit and don't be concerned if it asks again after you update openelec.
i think i finaly get my pi to work with my 1080p mkv's without problem i have change settings in xbmc in system -> VIdeo from 60hz to 24 and now my videos are not stuttering
mactalla wrote:smuggly wrote:Also when i ssh 192. blah blah blah i get a key error warning?
Thanks. smuggly
Hi all,
I might be coming across as a bit dim here, but I have a bluetooth dongle which I'm trying to use to pair a spare wiimote I have to use as a remote control for my RPi with OpenELEC, but I'm struggling to really see what I need to do.
If I put my wiimote in pair mode and run hcitool scan then it finds the wiimote fine, but the installation appears to be lacking the bluez-simple-agent utility and I can't see anything in the running xbmc to assist in pairing a device?
I've found other posts where people are using wiimotes with OE so I can only assume that I'm overlooking something simple?
I want video/movie output to go to HDMI and music to go to analog output (when TV is turned off). Is there any way to configure separate audio outputs for music and video?
If XBMC does not allow this what are workarounds, is there automatic switching for audio output(i.e. when hdmi is off switch to secondary/analog)?
Here is the link to the latest release (r11476)
http://www.mediafire.com/?ljnitzxphs9t6o5
This release includes my own patch which fixes the issue with h264 main and baseline profile videos being played with ff-h264 instead of omx-h264 (eg youtube videos being played at 1fps). I have tested it myself and it works!
humla wrote:Here is the link to the latest release (r11476)
Thanks, can you share patch only?
I use my own compilations, becouse I include LIRC GPIO driver patch in it [http://www.raspberrypi.org/phpBB3/viewtopic.php?f=45&t=7798] so it would be nice to have your patch in it too.
podly wrote:humla wrote:Here is the link to the latest release (r11476)
Not a problem, get it here.
http://www.mediafire.com/?1yrxyar1h0jjjtj
put it in here (if you dont already know)
OpenELEC.tv/packages/mediacenter/xbmc-rpi/patches/
humla wrote:podly wrote:humla wrote:Here is the link to the latest release (r11476)
Thanks, starting compilation ;]
humla wrote:Not a problem, get it here.
thanks much! added in https://github.com/OpenELEC/OpenELEC.tv ... 6eb29fafe1
Stephan
Is this included In The Latest IMG? If Not Can It Be Patched Easily? Thanks Smuggly
Just Seen It...
Just Seen It...
smuggly wrote:Is this included In The Latest IMG? If Not Can It Be Patched Easily? Thanks Smuggly
Just Seen It...
Now that it is in the openelec git tree u shouldn't have to do anything manually, just do a git pull and u should get the patch.
As for an img, wait for one by sparky, he goes daily IMG builds.
Can I Just ssh in and put it in the folder described?
I get my image from the ( openelec the state of me) from the other person (sraue) here in the thread. It's probably in his img already? Thanks smuggly
smuggly wrote:Can I Just ssh in and put it in the folder described?
Nope, you can't just use ssh. You have to compile last release from git or download prepatched r11476 from here: http://www.mediafire.com/?ljnitzxphs9t6o5 or download latest r11487 or newer. This one http://openelec.thestateofme.com/r11487.img.zip should be ok.
