mkkyah wrote:mkkyah wrote:Dear tom-pi and truehl,
I have tried that rc.local stop/start solution. It's not working for this case. I believe squeezelite is working but interfering with something.
Update: I was wrong, when I do "top", squeezelite is not there.
Ok, Problem solved with Truehl's incredible support, thanks for making all this experience so simple for us.
If you have a "Creative Sound Blaster Play" usb audio card, this may help you too until Truehl adds official support:
- change SLOPTIONS line at the end of the /etc/default/squeezelite file to this:
SLOPTIONS="-n PPP -o front:CARD=U0x41e0x30d3,DEV=0 " ( PPP is your player's name.)
- You can also do this during Squeezelite installation through setup menu. Setup asks you to open config, click yes and same file opens in editor, make the change there.
- probably you will need a reboot.
About SB PLay: Although I'm happy with the card, I was expecting more. Same speaker/dock sounds much better with iPhone+iPeng. I don't have any other card/DAC to compare, how are your experiences? BTW is there a chance to have an integrated EQ in Squeezeplug or Squeezelite?
Thanks again
