Dweeber wrote:Dave_PL wrote:I dont know what you are talking about. Ive configured Xbian today in about and hour. The only one problem Ive had was with my K400 keyboard. But now everything is ok.
You just need to run Programs->Xbian Settings and update to the newest version and this will install your wifi (MrEngman's script), update to 0.7v and also it can expand rootfs (which basically takes the most time).
1) Update to the newest version would normally mean it would need Network access? Without the WiFi working, there was no network access. There is no way to get an Ethernet cable to where it is located.
Maybe I wasnt so clear about updating to 0.7v.
All you need is to run Xbian Settings @ 0.6v. Script will just got WiFi working. After that run the script from xbian site (for update to 0.7v). When you have 0.7v run Xbian Settings one more time to get wifi working again and EXPAND your sd card. My16gb sd looks like this:
- Code: Select all
Filesystem Size Used Avail Use% Mounted on
rootfs 15G 667M 13G 5% /
/dev/root 15G 667M 13G 5% /
tmpfs 13M 340K 12M 3% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 25M 0 25M 0% /tmp
tmpfs 10M 0 10M 0% /dev
tmpfs 25M 0 25M 0% /run/shm
/dev/mmcblk0p1 75M 28M 48M 37% /boot
