jojojojojojo wrote:drgeoff wrote:scotspaul wrote:If your after a cheap USB DAC I've heard great things about this item, http://www.amazon.co.uk/FiiO-D3-Coaxial ... B0053VKP8S given its price.
I cannot say if the great things that apparently have been heard about that converter are true. I can say that it is definitely not a USB DAC. It has no USB interface. It requires a SPDIF input (coax or optical) which the RPi does not provide.
(Also, today's English lesson: The proper contraction of "you are" is "you're", not "your".)
So you say that picture 5 (top left corner pictures, the one with the schematics) in his link is wrong?
I'm not sure what picture you are referring to, but if you are asking about the mini-USB socket it is clearly labelled as "Power In DC 5v".. Anyway scotspaul has given a corrected link in a post above.
