milhouse wrote:in which case this workaround may no longer be necessary.
of course it's still necessary - unless you want to punish early adopters
jaromanda wrote:milhouse wrote:in which case this workaround may no longer be necessary.
milhouse wrote:jaromanda wrote:milhouse wrote:in which case this workaround may no longer be necessary.
Obviously I meant "not necessary for those with 512MB".
jaromanda wrote:UPnP is broken since r12055 or so
Also broken in XBian - so I'm guessing it's an XBMC problem
jaromanda wrote: that makes as much sense as flyscreens on a submarine - UPnP didn't need improving .... now it does
b0x wrote:liking 12080 new can't turn off the tv feature(it keeps turning it back on)
i see an update for cec has already been added. unplugged the pi in the mean time.
rapzak wrote:Hi,
I got a Panasonic TV - TH-50PZ700E
I have logged all the keys from the remote, and i could not get the DVD/VCR playback buttons to work on CEC, maybe i have to play a litle with viera link settings, i have tried to re-config the remote with the hold power off + 7 + 3 + stop with no luck..
I got this mapping:
Panasonic (008045)
OK = select (0)
Right = right(4)
Left = left(3)
Up = UP(1)
Down = down(2)
Return = exit (d)
Exit = clear (2c)
Option = setup menu (a)
Red = F2 (red) (72)
Green = F3 (green) (72)
Yellow = F4 (yellow) (74)
Blue = F1 (blue) (71)
Will this be sufficient buttons to control XBMC, seems to miss playback stop etc.?
Is it the remote.xml i need to change, and i believe it is the F1-F4 commend i need to put in for the Red to blue buttons?
Kasper
Benoe wrote:rapzak wrote:Hi,
Return = exit (d)
Exit = clear (2c)
Kasper
I have the same buttons from my Panasonic remote, and I use the attached remote.xml
wave wrote:I can also confirm that with newer builds when streaming mpeg4(h264) doesnt work...with r11999 everything is OK.
rapzak wrote:Benoe wrote:rapzak wrote:Hi,
Return = exit (d)
Exit = clear (2c)
Kasper
Thank you so MUCH!
But can you tell me how the Exit CEC command is linked to the XBMC back command?
I have problem if i see a movie to get out??
I am new in XBMC also, but will try your file
Kasper
Benoe wrote:rapzak wrote:Benoe wrote:Hi,
Return = exit (d)
Exit = clear (2c)
Kasper
I mapped the exit key to full screen video toggle, pressing that during play will show me main menu (with the movie playing in background)
rapzak wrote:how is Remote Return key (Exit) mapped to XBMC command back??
Kasper
caravela wrote:
- Code: Select all
mount -o remount /flash -rw
vi /flash/config.txt
press a
type the configurations (mine bellow)
force_turbo=0
arm_freq=900
core_freq=333
sdram_freq=450
over_voltage=2
press :
write wq!
reboot
