Hi.
I want to write a batch program to stress the CPU for temperature checking (using an IR gun) that does something like this in an xwindows terminal window (to keep things simple):-
Calculate 22 divided by 7 to e.g, 10 places then display the result then do it again x times where x can be modified by editing the batch program.
I would prefer a simple loop that 61-year-old kids like me can follow:-
for n=1 to x
22 /7 (display the result to 10 places in the terminal window)
next n
Any ideas?
Batch program in Xwindows
You could use a while loop and never have the condition fulfilled such that you have to ctrl+c to end it after your tests
Dear forum: Play nice
Can you give me an xwindows terminal code example where the result is calculated to e.g., 10 decimal places?
TIA, Ray
TIA, Ray
I'll give it some thought. The more I consider it, I'm not sure if running such a loop would tax the processor as much as you'd like. Just having the gui up at all seems to tax it a fair deal... you might be better off writing a script to refresh a simple webpage every x seconds and tax it a lot more!
abishur wrote:I'll give it some thought. The more I consider it, I'm not sure if running such a loop would tax the processor as much as you'd like. Just having the gui up at all seems to tax it a fair deal... you might be better off writing a script to refresh a simple webpage every x seconds and tax it a lot more!
There is a debian package called cpuburn which is specifically designed for stress-testing the cpu.
