- Code: Select all
# Straight forward Makefile to compile all examples in a row
# If cross-compiling, you may wish to set the following environment variable to the root location of
# your 'sdk'
# SDKSTAGE=/home/foo/raspberrypi
INCDIR=-I./Common -I$(SDKSTAGE)/opt/vc/include -I$(SDKSTAGE)/opt/vc/include/interface/vcos/pthreads
LIBS=-lGLESv2 -lEGL -lm -lbcm_host -L$(SDKSTAGE)/opt/vc/lib
CFLAGS+=-DRPI_NO_X
# CFLAGS+=-DRPI_NO_X -DSTANDALONE -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -DTARGET_POSIX -D_LINUX -fPIC -DPIC -D_REENTRANT -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -U_FORTIFY_SOURCE -Wall -g -DHAVE_LIBOPENMAX=2 -DOMX -DOMX_SKIP64BIT -ftree-vectorize -pipe -DUSE_EXTERNAL_OMX -DHAVE_LIBBCM_HOST -DUSE_EXTERNAL_LIBBCM_HOST -DUSE_VCHIQ_ARM -Wno-psabi -I$(SDKSTAGE)/opt/vc/include/ -I./ -I$(SDKSTAGE)/opt/vc/lib
COMMONSRC=./Common/esShader.c \
./Common/esTransform.c \
./Common/esShapes.c \
./Common/esUtil.c
COMMONHRD=esUtil.h
CH02SRC=./main.c
default: all
all: main.c
clean:
find . -name "CH??_*" | xargs rm -f
main.c: ${COMMONSRC} ${COMMONHDR} ${CH02SRC}
gcc $(CFLAGS) ${COMMONSRC} ${CH02SRC} -o ./$@ ${INCDIR} ${LIBS}
and the error I keep getting is:
make: Circular main.c <- main.c dependency dropped.
make: Nothing to be done for `default'.
I honestly have no idea so any help would be nice.
Thanks in advance.
