Porting cmake
by higgins-demack » Sat Jul 07, 2012 11:58 pm
The good news: It works. Just build from source using the instructions in the cmake (2.8.8) distro.
The bad news: You can't do it in a terminal on the desktop. Compiling goes smoothly but the linker bombs. It guess it runs out of memory. Kill off everything but the "bare" command line and do your "make" from there.
by plugwash » Sun Jul 08, 2012 5:48 pm
Which distro are you using and is there something wrong with the cmake they are shipping?
Moderator
by jamesh » Mon Jul 09, 2012 1:41 am
I just installed the distro cmake - seemed to work fine. Quite a while ago though.
Moderator
by higgins-demack » Thu Jul 12, 2012 11:12 am
To answer the question by plugwash, I'm using Debian. There's nothing wrong with the repository version as far as I'm aware, but last time I looked it was several points behind the latest release.
by jdbennet » Wed Jul 25, 2012 5:38 pm
CMake makes cross-compiling very easy..... just run it on your desktop?
by mnajera » Wed Jul 25, 2012 9:51 pm
I can confirm that cmake builds under Raspian, at least from the basic terminal (without running X). It took a very long time to build, though.
