I have once again stumbled upon a problem which I have been trying to solve for a good amount of time but to no avail.. I am currently trying to control the Parallax Propeller Servo Controller via Debian Linux on the Raspberry Pi.
User manual for the controller: http://www.parallax.com/Portals/0/Downl ... e-v1.1.pdf
I have done all of the nitty gritty work of opening up a virtual serial port and being able to read from the device but I am having major problems writing commands to the controller.
It all basically comes down to one function which in C is write(). The Servo Controller requires 8 bytes of information to set a position of a servo so I need the following format
Syntax: “!SC” <channel> <ramp speed> <lowbyte> <highbyte> <CR>
Reply: None
So using the write C command which is in the following format:
#include <fcntl.h>
int write( int handle, void *buffer, int nbyte );
I have successfully passed "CHARACTERS" to the servo controlller. (ex. !SCVER?) However when I try to send a mix of characters AND integers I come across problems, the servo controller does not respond to my commands.
Here is my command
n = write(tty_fd,("!SC",&i,&i,&lowbyte,&highbyte,"\r"),8);
I do not think this is in the correct format.... Could anyone lend a helping hand in helping me solve this problem? I tried googling for hours but with little luck. The mix of characters and integers is what seems to be the problem. I would send all 8 bytes of characters instead of mixing integers but since decimals 0-31 are not typical characters, writing these values is not easy. I also tried splitting up the write command into first sending the characters !SC and then the integers separately and then the return carriage but that did not work either....
I have also tried sending all hex values using this code but it did not work also:
- Code: Select all
char buf[8] = {0x21,0x53,0x43,0x00,0x00,0x20,0x03,'\r'}; //!SC 0 0 32 3 \r
n = write(tty_fd,buf,8);
I have also seen Gordons WiringPi Serial Library but it only has commands that send one character out at a time and I need to send 8 bytes..
Many Thanks!
Robert
Here is the entire code:
- Code: Select all
#include <string.h>#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <termios.h>
#include <wiringSerial.h>
int main(int argc,char** argv)
struct termios tio;
struct termios stdio;
struct termios old_stdio;
int tty_fd;
unsigned char c='D';
tcgetattr(STDOUT_FILENO,&old_stdio);
memset(&stdio,0,sizeof(stdio));
stdio.c_iflag=0;
stdio.c_oflag=0;
stdio.c_cflag=0;
stdio.c_lflag=0;
stdio.c_cc[VMIN]=1;
stdio.c_cc[VTIME]=0;
tcsetattr(STDOUT_FILENO,TCSANOW,&stdio);
tcsetattr(STDOUT_FILENO,TCSAFLUSH,&stdio);
fcntl(STDIN_FILENO, F_SETFL, O_NONBLOCK); // make the reads non-blocking
memset(&tio,0,sizeof(tio));
tio.c_iflag=0;
tio.c_oflag=0;
tio.c_cflag=CS8|CREAD|CLOCAL; // 8n1, see termios.h for more information
tio.c_lflag=0;
tio.c_cc[VMIN]=1;
tio.c_cc[VTIME]=5;
tty_fd=open("/dev/ttyUSB0", O_RDWR | O_NONBLOCK);
cfsetospeed(&tio,B2400); // 115200 baud
cfsetispeed(&tio,B2400); // 115200 baud
tcsetattr(tty_fd,TCSANOW,&tio);
int count = 0;
int n=0;
unsigned char buffer[8];
//FIND LOWBYTE AND HIGHBYTE BASED ON INPUTED SPEED
int speed = 800;
printf("speed: %d\n\r", speed);
int highbyte = speed >> 8;
printf("highbyte: %d\n\r", highbyte);
highbyte = highbyte << 8;
int lowbyte = speed-highbyte;
printf("lowbyte: %d\n\r", lowbyte);
if (n < 0)
fputs("write() of 8 bytes failed!\n\r", stderr);
else
printf ("Write succeed n = %i\n\r", n );
close(tty_fd);
tcsetattr(STDOUT_FILENO,TCSANOW,&old_stdio);
return EXIT_SUCCESS;
