working with times and dates
by stevep » Sun Jun 10, 2012 6:39 pm
This might belong in the beginners section, but it's Python so here goes. I've got a gps dongle connected, which is returning all the usual data, including time. I've written a few lines to extract the time (formatted as seconds from the epoch, so something like 1339324998.14). This then has to be converted to something more user friendly (- I struggled with this bit and there is probably a better way).
two simple questions:
1. The Hour and Minute values returned are in the format '18' and '30' including the quote marks. I don't know if this is a Python thing, but I want simple numerical values, not a text string. How do I strip out the quote marks and ensure that I am left with a numerical value (one that I can do some maths with at a later date).
2. When I run the code in a terminal window, it obviously loops round, looking at the gps dongle every few seconds and displaying the results. I want to stop the program running, but keep the last set of results displayed in the terminal window so I can copy and paste the output. Ctrl+C just shuts it completely. Any suggestions?
Answers in words of one syllable or less please, it's taken me all day to write the following and get it to work:
#timetest1.py
from datetime import datetime
import time, os, gps, calendar
session = gps.gps(host="localhost", port="2947")
session.poll()
session.stream()
while 1:
   os.system("clear")
   session.poll()
   print "Just for info:"
   print "time GPS " ,  session.fix.time
   print "time utc " ,  session.utc, session.fix.time
   print "***************"
   timestamp = session.fix.time
   print "Simple check for syntax:"
   print repr(timestamp)
   print "****************"
   print "[1]"
   time_gmtuple = time.gmtime(timestamp)
   print "This is the time according to the GPS dongle"
   print repr(time_gmtuple) #***
   print "******************"
   print "[2]"
   print "As for [1] but converted to a sort of string"
   dt_obj = datetime.utcfromtimestamp(timestamp)
   print repr(dt_obj)
   print "[3]"
   print "Extract the <Hours> value from the string"
   extract_hrs = dt_obj.strftime("%H")
   print repr(extract_hrs)
   print "[4]"
   print "Extract the <Minutes> value from the string"
   extract_min = dt_obj.strftime("%M")
   print repr(extract_min)
   for i in session.satellites:
      print "t", i
   time.sleep(5)
by yeahbox » Sun Jun 10, 2012 11:00 pm
1) If you know that the value you want to convert really is an integer, you can just use int() to convert it, like for example int('21') will result in the integer 21. This will raise an exception if it can't be converted.
2) You could use a try-except:
import time
try:
    while True:
        hour = time.strftime("%H")
        print hour, type(hour)
        hour = int(hour)
        time.sleep(1)
except KeyboardInterrupt:
    print "Good bye!"
by bhoga » Sun Jun 10, 2012 11:29 pm
If you just want an integer hour or minute value, you can get it easily once you have a datetime object:
dt_obj.hour
dt_obj.minute
In a python console you can type
dir(dt_obj)
To get a list of methods and properties of any variable. You can try help(object) too.
Have fun!
by texy » Mon Jun 11, 2012 6:38 am
Which GPS dongle do you have?
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation ;-)
Moderator
by stevep » Mon Jun 11, 2012 6:44 am
Really helpful answers, thanks guys. I'll have a play later today.
The dongle is a Bluenext 903s, around £16 from Scan Computers (uk).
by kasperl » Mon Jun 11, 2012 10:32 am
As for doing maths on the times, it might be easier to do that in seconds from epoch than in hour,minutes kinds of stuff.
by wrhii » Sun Jun 17, 2012 7:28 pm
Any easy method of working with Date/Time is to use:
from datetime import date, timedelta
def elapse_time(starttime):
    result=[]
    curr_time=datetime.datetime.now()   # capture current time of execution.
    result=curr_time-starttime
    return result
starttime is set using the following:
stime=datetime.datetime.now()   # capture start time of execution.
The elapse_time function will give you...the elapsed time, and can be called with code such as used here.
print 'Elapsed time: %s' % ('',elapse_time(stime))
The time printed is in a user meaningful format. Other format options are available, you will need to review the format options for datetime.
Lots of options on what you see when using datetime.
Alternately, you can do date arithmetic with the "date" function and timedelta. The following code sample will take today's date, and subtract some number of days, and then set the result into del_basedate.
del_basedate = date.today() - timedelta(days=cmd.age)
by karl101 » Wed Jun 20, 2012 2:00 pm
hello,
is this of any use?
#! /usr/bin/python
import time
#time from the gps, needs to be a floating number, not a string
epochTime = float("1339324998.14")
#convert into a python tuple format
pyTime    = time.gmtime(epochTime)
print pyTime
#convert into a string (SQL reverse date style)
# http://docs.python.org/library/time.html#time.strftime
sqlDate   = time.strftime("%Y-%m-%d %H:%M:%S", pyTime)
print sqlDate
I have always found when doing calculations with dates and time, is to keep them in a date/time format, like pyTime above, rather than convert them into integers.
detecting a keypress seems to be more difficult than it should be, I found this and it seems to work:
#! /usr/bin/python
## taken from: http://www.darkcoding.net/software/non-blocking-console-io-is-not-possible/
import sys
import select
import tty
import termios
def isData():
  return select.select([sys.stdin], [], [], 0) == ([sys.stdin], [], [])
old_settings = termios.tcgetattr(sys.stdin)
try:
  tty.setcbreak(sys.stdin.fileno())
  i = 0
  while 1:
    print i
    i += 1
    if isData():
      c = sys.stdin.read(1)
      if c == '\x1b':         # x1b is ESC
        break
finally:
  termios.tcsetattr(sys.stdin, termios.TCSADRAIN, old_settings)
Karl.
