Hi, I'm just starting out using Python and I have a few questions if you don't mind answering. If they have been answered else where then any pointer on where to look would be much appreciated.
I'm using the standard latest Debian image, and using the LXDE. I'm trying to get my head around and have a play with using Python with Pygame and also access the GPIO
First question is what is the difference between IDLE and IDLE 3 and which one am I best to use?
Second question is how do I run my Python programme as root. I've run a couple of example Python programmes that access the GPIOs, and they work ok from terminal when run using the SUDO command but when I run them from within IDLE I am getting permission denied messages.
Any help and advice would be very much appriciated
A bit of help for the Python beginner
Just to add, I am connecting to the RaspberryPi using TightVNC, I have tried running "sudo idle" and "sudo idle3" from a terminal window, but I get an error message saying "Client is not authorised to connect to ServerTraceback .........."
AforAlex wrote:First question is what is the difference between IDLE and IDLE 3 and which one am I best to use?
IDLE is for python 2.x and IDLE 3 is for python 3.x. Depending on which tutorials / examples you're following, you may want to use python 2 or 3. Google "python 2 vs 3" and you'll find lots of information about the differences. If you're following a book that is based on python 2 you'd definitely want to use IDLE / python 2.
As I understand it, Python 2 is still the default for Debian / Raspbian wheezy. So when you install pygame (from a terminal: sudo apt-get install python-pygame) the version installed is for python 2.
If you want to use pygame with IDLE 3 / python 3, you'll need to install it manually as described here:
viewtopic.php?p=188760#p188760
(this probably takes around 30 minutes or so)
I haven't tried any of the GPIO stuff yet so can't help there. Looking forward to it, though.
I've done a few things with GPIO, and I've always used IDLE, which is for Python 2, and not IDLE 3 which is for Python 3. While I would love to be able to run it from IDLE, I haven't been able to figure that one out myself. I've always just run them from a command line using sudo, as you've mentioned.
Not much help, but maybe it's a little.
Rick
Rick
There are 10 types of people in this world. Those that understand binary, and those that don't.
Thank you very much, very useful.
I've been having a play, i think i have opted for Geany as an IDE to use ... I don't know what it is, but just looks and feels a little bit cleaner than IDLE.
I've managed to also work out the other problem I was having which was to do with user rights and accessing the XServer remotely using TightVNC. Bassically the VNC was running under the user Pi, which was not root, I could run commands in Terminal with the SUDO command, but I couldn't launch anything that interfaced with the desktop as SUDO ... the solution was (or at least my solution) was to alter the tightVNCServer config file in the init.d directory and change the user from "Pi" to "Root".
I lost my desktop icons but it means that u can now run things as root if needed.
Once again many thanks everyone
