A simple program controlling Raspberry Pi GPIO
by hzhwang » Mon Nov 05, 2012 11:16 pm
Hi everyone,
I wrote a simple program that control GPIO in LXDE. Currently you can control GPIO 4,17,18,21,22,23,24,25 high/low just simply press the button.
Video:
http://www.youtube.com/watch?v=15m4-KmMlJM
I am new to Raspberry Pi hardware and Python/Tkinter. I wrote it under Raspbian, it should works for other distributions. But remember this program must run as root.
It still under development, and need your kindly comment and suggestions.
Thank you in advance.
from Tkinter import *
import RPi.GPIO as GPIO
import time
GPIO.setmode( GPIO.BCM )
GPIO.setup( 4, GPIO.OUT)
GPIO.setup(17, GPIO.OUT)
GPIO.setup(18, GPIO.OUT)
GPIO.setup(21, GPIO.OUT)
GPIO.setup(22, GPIO.OUT)
GPIO.setup(23, GPIO.OUT)
GPIO.setup(24, GPIO.OUT)
GPIO.setup(25, GPIO.OUT)
class App:
    io4=0
    io17=0
    io18=0
    io21=0
    io22=0
    io23=0
    io24=0
    io25=0
def __init__(self, master):
        frame = Frame(master)
        frame.pack()
        self.p1 = Button(frame, text="3V3 Power", fg="yellow", command=self.reserved)
        self.p1.pack(side=LEFT)
        self.p1.grid(row=0,column=0)
        self.p2 = Button(frame, text="5V Power", fg="red", command=self.reserved)
        self.p2.pack(side=LEFT)
        self.p2.grid(row=0,column=1)
        self.p3 = Button(frame, text="GPIO 0", fg="blue", command=self.reserved)
        self.p3.pack(side=LEFT)
        self.p3.grid(row=1,column=0)
        self.p4 = Button(frame, text="5V Power", fg="red",command=self.reserved)
        self.p4.pack(side=LEFT)
        self.p4.grid(row=1,column=1)
        self.p5 = Button(frame, text="GPIO 1", fg="blue",command=self.reserved)
        self.p5.pack(side=LEFT)
        self.p5.grid(row=2,column=0)
        self.p6 = Button(frame, text="Ground", command=self.reserved)
        self.p6.pack(side=LEFT)
        self.p6.grid(row=2,column=1)
        self.p7 = Button(frame, text="GPIO 4",fg="green", command=self.gpio4)
        self.p7.pack(side=LEFT)
        self.p7.grid(row=3,column=0)
        self.p8 = Button(frame, text="GPIO 14",fg="yellow", command=self.reserved)
        self.p8.pack(side=LEFT)
        self.p8.grid(row=3,column=1)
        self.p9 = Button(frame, text="Ground", command=self.reserved)
        self.p9.pack(side=LEFT)
        self.p9.grid(row=4,column=0)
        self.p10 = Button(frame, text="GPIO 15",fg="yellow", command=self.reserved)
        self.p10.pack(side=LEFT)
        self.p10.grid(row=4,column=1)
        self.p11 = Button(frame, text="GPIO 17",fg="green", command=self.reserved)
        self.p11.pack(side=LEFT)
        self.p11.grid(row=5,column=0)
        self.p12 = Button(frame, text="GPIO 18",fg="green", command=self.reserved)
        self.p12.pack(side=LEFT)
        self.p12.grid(row=5,column=1)
        self.p13 = Button(frame, text="GPIO 21",fg="green", command=self.reserved)
        self.p13.pack(side=LEFT)
        self.p13.grid(row=6,column=0)
        self.p14 = Button(frame, text="Ground", command=self.reserved)
        self.p14.pack(side=LEFT)
        self.p14.grid(row=6,column=1)
        self.p15 = Button(frame, text="GPIO 22",fg="green", command=self.gpio22)
        self.p15.pack(side=LEFT)
        self.p15.grid(row=7,column=0)
        self.p16 = Button(frame, text="GPIO 23",fg="green", command=self.gpio23)
        self.p16.pack(side=LEFT)
        self.p16.grid(row=7,column=1)
        self.p17 = Button(frame, text="3V3 Power",fg="yellow", command=self.reserved)
        self.p17.pack(side=LEFT)
        self.p17.grid(row=8,column=0)
        self.p18 = Button(frame, text="GPIO 24",fg="green", command=self.gpio24)
        self.p18.pack(side=LEFT)
        self.p18.grid(row=8,column=1)
        self.p19 = Button(frame, text="GPIO 10", fg="purple",command=self.reserved)
        self.p19.pack(side=LEFT)
        self.p19.grid(row=9,column=0)
        self.p20 = Button(frame, text="Ground", command=self.reserved)
        self.p20.pack(side=LEFT)
        self.p20.grid(row=9,column=1)
        self.p21 = Button(frame, text="GPIO 9", fg="purple",command=self.reserved)
        self.p21.pack(side=LEFT)
        self.p21.grid(row=10,column=0)
        self.p22 = Button(frame, text="GPIO 25", fg="green",command=self.gpio25)
        self.p22.pack(side=LEFT)
        self.p22.grid(row=10,column=1)
        self.p23 = Button(frame, text="GPIO 11", fg="purple",command=self.reserved)
        self.p23.pack(side=LEFT)
        self.p23.grid(row=11,column=0)
        self.p24 = Button(frame, text="GPIO 8", fg="purple",command=self.reserved)
        self.p24.pack(side=LEFT)
        self.p24.grid(row=11,column=1)
        self.p25 = Button(frame, text="Ground", command=self.reserved)
        self.p25.pack(side=LEFT)
        self.p25.grid(row=12,column=0)
        self.p26 = Button(frame, text="GPIO 7", fg="purple",command=self.reserved)
        self.p26.pack(side=LEFT)
        self.p26.grid(row=12,column=1)
    def gpio4(self):
        if self.io4==0:
          GPIO.output(4, GPIO.HIGH)
          self.io4=1
        else:
          GPIO.output(4, GPIO.LOW)
          self.io4=0
        return
    def gpio17(self):
        if self.io17==0:
          GPIO.output(17, GPIO.HIGH)
          self.io17=1
        else:
          GPIO.output(17, GPIO.LOW)
          self.io17=0
        return
    def gpio18(self):
        if self.io18==0:
          GPIO.output(18, GPIO.HIGH)
          self.io18=1
        else:
          GPIO.output(18, GPIO.LOW)
          self.io18=0
        return
    def gpio21(self):
        if self.io21==0:
          GPIO.output(21, GPIO.HIGH)
          self.io21=1
        else:
          GPIO.output(21, GPIO.LOW)
          self.io21=0
        return
    def gpio22(self):
        if self.io22==0:
          GPIO.output(22, GPIO.HIGH)
          self.io22=1
        else:
          GPIO.output(22, GPIO.LOW)
          self.io22=0
        return
    def gpio23(self):
        if self.io23==0:
          GPIO.output(23, GPIO.HIGH)
          self.io23=1
        else:
          GPIO.output(23, GPIO.LOW)
          self.io23=0
        return
    def gpio24(self):
        if self.io24==0:
          GPIO.output(24, GPIO.HIGH)
          self.io24=1
        else:
          GPIO.output(24, GPIO.LOW)
          self.io24=0
        return
    def gpio25(self):
        if self.io25==0:
          GPIO.output(25, GPIO.HIGH)
          self.io25=1
        else:
          GPIO.output(25, GPIO.LOW)
          self.io25=0
        return
    def reserved(self):
        return
root = Tk()
app = App(root)
root.mainloop()
My RaspberryPi playground http://ezzep.blogspot.com
by sompor9 » Tue Nov 06, 2012 8:05 am
Thank you so much
by vallesasecas » Tue Nov 06, 2012 8:09 am
Thanks for your code lines!
Ill try to use a little to understand a little better the uses of GPIO in raspberry...step by step.
by BlackJack » Tue Nov 06, 2012 8:42 am
@hzhwang: Way too much code repitition. When you copy and pasting a piece of code over and over again think a moment about the differences and make a function of it that gets the differences as arguments.
Numbering names is very often a sign you actually want a list or some other data structure instead of all the names. All the `p*` attributes are not even used.
You are `pack()`\ing *and* `grid()`\ing all buttons – the `pack()` has no effect then. There can always be just one layout manager for placing a widget.
Asterisk imports pollute the namespace of the module. `Tkinter` contains ≈190 names. It makes finding out where a name comes from harder if more than one *-import is used. And there is the risk of name collisions — several modules containing the same name for different things. With `Tkinter` it is common to import it as `tk`.
The `time` import is not used anywhere.
The `io*` names should not be defined at class level. They are instance attributes. And a dictionary mapping pin number to state would be more flexible.
Untested:
import Tkinter as tk
from functools import partial
class App(object):
        frame = tk.Frame(master)
        frame.pack()
        pins = [4, 17, 18, 21, 22, 23, 24, 25]
        GPIO.setmode(GPIO.BCM)
        for pin in pins:
            GPIO.setup(pin, GPIO.OUT)
        self.pin_states = dict((p, False) for p in pins)
        # Green is a special color only to be used for the pins that can be
        # toggled.
        columns_data = [
                ('3V3 Power', 'yellow'),
                (0, 'blue'),
                (1, 'blue'),
                (4, 'green'),
                ('Ground', 'black'),
                (17, 'green'),
                (21, 'green'),
                (22, 'green'),
                (10, 'purple'),
                (9, 'purple'),
                (11, 'purple'),
                ('5V Power', 'red'),
                (14, 'yellow'),
                (15, 'yellow'),
                (18, 'green'),
                (23, 'green'),
                (24, 'green'),
                (25, 'green'),
                (8, 'purple'),
                (7, 'purple'),
        for column_no, column_data in enumerate(columns_data):
            for row_no, (value, colour) in enumerate(column_data):
                text = 'GPIO %d' % value if isinstance(value, int) else value
                command = (
                    partial(self.toggle_pin, value)
                    if colour == 'green'
                    else None
                assert (
                    colour == 'green' and value in self.pin_states
                    or colour != 'green' and value not in self.pin_states
                button = tk.Button(frame, text, fg=colour, command=command)
                button.grid(row=row_no, column=column_no, sticky='WE')
    def toggle_pin(self, pin):
        self.pin_states[pin] = state = not self.pin_states[pin]
        GPIO.output(pin, state)
def main():
    root = tk.Tk()
    app = App(root)
    root.mainloop()
if __name__ == '__main__':
    main()
while not self.asleep():
    sheep += 1
by hzhwang » Tue Nov 06, 2012 8:56 am
Sorry everyone
I found a problem in my code, I didn't notice it when I paste the code
class App:
    io4=0
    io17=0
    io18=0
    io21=0
    io22=0
    io23=0
    io24=0
    io25=0
should be:
class App:
    io4=0
    io17=0
    io18=0
    io21=0
    io22=0
    io23=0
    io24=0
    io25=0
Source code can be download here:
https://s3.amazonaws.com/HZ-Studio/rpi_gpio_gui.py.zip
Sorry for any inconvenience
by hzhwang » Tue Nov 06, 2012 9:00 am
BlackJack wrote:@hzhwang: Way too much code repitition. When you copy and pasting a piece of code over and over again think a moment about the differences and make a function of it that gets the differences as arguments.
Thank for your comment and suggestions ,it helps.
I will refine my code again.
Thank you
by rlust » Thu Nov 08, 2012 11:46 pm
Trying out this code.
When I press the button on one of the GPIO buttons let's say 17 should the output go low.
I was hooking it to a led with a current limiting resistor. I thought the led would turn off, but it stays on when I press the button. Am I missing something here?
thanks for the code!!
Well done!
Randy
by techpaul » Fri Nov 09, 2012 10:00 am
rlust wrote:Trying out this code.
Well done!
Randy
If the code has been done to use GPIO pin connector numbering - pin 17 is 3V3 power and cannot be turned low, except by powering down the whole Pi. If done as chip numbering then yes pin 11 on connector should go low.
The code shows that only those with green writing can be changed.
A quick scan of peoples code suggest they have a mix up between connector and chip numbering their code. Whilst the graphic interface is done as connector pin numbering, probably would be more understandable code to match the graphic so connector pin numbering was used throughout
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
by sompor9 » Sat Nov 10, 2012 11:32 am
Hi All
Please recommend me to fix error when run program
ScreenHunter_12 Nov. 10 18.30.jpg (23.36 KiB) Viewed 5776 times
by techpaul » Sat Nov 10, 2012 12:16 pm
sompor9 wrote:Hi All
As it says you need to run as root.
Looks like you are in Windows interface and running IDLE by the icon
When trying to do IDLE and access GPIO do it this way
Start menu button
Click RUN
Enter in box
sudo IDLE
Then try your test
by sompor9 » Sun Nov 11, 2012 5:00 am
Please help me agian
i found this error but i check lib normaly
and lib installed alrealy
ScreenHunter_15 Nov. 11 11.56.jpg (27.88 KiB) Viewed 5692 times
by sompor9 » Sun Nov 11, 2012 5:02 am
Installed library alreadly.
ScreenHunter_16 Nov. 11 11.58.jpg (33.56 KiB) Viewed 5692 times
by croston » Sun Nov 11, 2012 8:35 am
Do you have any files or directories named RPi, RPi.py, GPIO, or GPIO.py in the same area as your script?
by sompor9 » Sun Nov 11, 2012 10:49 am
Thanks for you answer
please more explaint issue about any GPIO file on the same directory..
and I have more detial for analyze this.
sudo python blink.py --> work
sudo ./blink.py --> not work
ScreenHunter_17 Nov. 11 17.45.jpg (44.39 KiB) Viewed 5648 times
by sompor9 » Sun Nov 11, 2012 11:01 am
This is blink.py for test my GPIO Function on top issue
#' /usr/bin/python
import time
count = 1
GPIO.setmode(GPIO.BOARD)
GPIO.setup(26,GPIO.OUT)
while (count <= 10):
        print '------ tick : ',count
        GPIO.output(26,GPIO.HIGH)
        print 'LED ON'
        time.sleep(.5)
        GPIO.output(26,GPIO.LOW)
        print 'LED OFF'
        time.sleep(.5)
        count = count + 1
GPIO.cleanup()
by techpaul » Sun Nov 11, 2012 1:02 pm
Change from this
#' /usr/bin/python
To this
#! /usr/bin/python
You had a typo
by hzhwang » Sun Dec 09, 2012 11:19 pm
Thanks for everyone comments and suggestions and sorry for late reply
This program requires RPi.GPIO Library and must run as root. It works under Rev.B v1.0, v2.0 may need some modification. GPIO numbering and color is referred to RPi Low-level peripherals - eLinux.org
http://elinux.org/Rpi_Low-level_periphe ... troduction
I made few change about graphic interface and hope it become more understandable. I rewrote the code and now is much simpler than before (I think)
Currently this program can control GPIO 4, 7, 8, 9, 10, 11, 14, 15, 17, 18, 21/27, 22, 23, 24, 25 output status high/low just simply press the button.
by charleslinquist » Mon Dec 10, 2012 4:32 pm
I'm trying to use the example, but I can't figure out how to load the RPi.GPIO library.
I went to the source,
http://code.google.com/p/raspberry-gpio ... loads/list
and tried
"wget http://code.google.com/p/raspberry-gpio ... b&can=2&q="
But that didn't work. So how do I get the library?
And when I invoke Python, and put the source there, and save the file with the extension .py, how do I make the file executable? Do I have to create a shell script such as -
#! bin/bash
example.py
and make it executable with chmod +x (name of my new shell script) ?
by hzhwang » Mon Dec 10, 2012 5:04 pm
charleslinquist wrote:I'm trying to use the example, but I can't figure out how to load the RPi.GPIO library.
and tried
I remember I download it by using midori (Browser in Raspbian's LXDE)
#! bin/bash
example.py
This program must run under LXDE, use the root Terminal and execute following command:
python rpi_gpio_gui.py
by charleslinquist » Mon Dec 10, 2012 6:49 pm
Isn't there a command-line way to do these things? I don't use LXDE at all.
by texy » Tue Dec 11, 2012 9:48 pm
You don't need to install RPi.GPIO for raspbian - it comes pre installed with the image.
At least for the latest and perhaps the last few versions.
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation ;-)
Moderator
