With thanks to Matt Hawkins of
http://www.raspberrypi-spy.co.uk fame, here is updated code which implements RPi.GPIO to drive the LCD and wiringpi to
drive the backlight LED via hardware PWM :
- Code: Select all
#!/usr/bin/python
# HD44780 LCD Test Script for
# Raspberry Pi
# Author : Matt Hawkins + Texy
# Site : http://www.raspberrypi-spy.co.uk
# Date : 28/10/2012
# uses RPi.GPIO to drive the LCD and
# wiringpi to drive the backlight LED via hardware PWM
#import
import RPi.GPIO as GPIO
import time
import wiringpi
# Define GPIO to LCD mapping
LCD_RS = 17
LCD_E = 4
LCD_D4 = 24
LCD_D5 = 22
LCD_D6 = 23
LCD_D7 = 21
LCD_LED = 18
# Define some device constants
LCD_WIDTH = 16 # Maximum characters per line
LCD_CHR = True
LCD_CMD = False
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
# Timing constants
E_PULSE = 0.00005
E_DELAY = 0.00005
def main():
# Main program block
GPIO.setmode(GPIO.BCM) # Use BCM GPIO numbers
GPIO.setwarnings(False)
GPIO.setup(LCD_E, GPIO.OUT) # E
GPIO.setup(LCD_RS, GPIO.OUT) # RS
GPIO.setup(LCD_D4, GPIO.OUT) # DB4
GPIO.setup(LCD_D5, GPIO.OUT) # DB5
GPIO.setup(LCD_D6, GPIO.OUT) # DB6
GPIO.setup(LCD_D7, GPIO.OUT) # DB7
wiringpi.wiringPiSetupGpio()
wiringpi.pinMode(LCD_LED, 2) # LED set up as PWM
wiringpi.pwmWrite(LCD_LED, 128)
# Initialise display
lcd_init()
# Send some test
lcd_byte(LCD_LINE_1, LCD_CMD)
lcd_string("wiringpi and")
lcd_byte(LCD_LINE_2, LCD_CMD)
lcd_string("RPi.GPIO 2gether")
def lcd_init():
lcd_byte(0x33,LCD_CMD)
lcd_byte(0x32,LCD_CMD)
lcd_byte(0x28,LCD_CMD)
lcd_byte(0x0C,LCD_CMD)
lcd_byte(0x06,LCD_CMD)
lcd_byte(0x01,LCD_CMD)
def lcd_string(message):
# Send string to display
message = message.ljust(LCD_WIDTH," ")
for i in range(LCD_WIDTH):
lcd_byte(ord(message[i]),LCD_CHR)
def lcd_byte(bits, mode):
# Send byte to data pins
# bits = data
# mode = True for character
# False for command
GPIO.output(LCD_RS, mode) # RS
# High bits
GPIO.output(LCD_D4, False)
GPIO.output(LCD_D5, False)
GPIO.output(LCD_D6, False)
GPIO.output(LCD_D7, False)
if bits&0x10==0x10:
GPIO.output(LCD_D4, True)
if bits&0x20==0x20:
GPIO.output(LCD_D5, True)
if bits&0x40==0x40:
GPIO.output(LCD_D6, True)
if bits&0x80==0x80:
GPIO.output(LCD_D7, True)
# Toggle 'Enable' pin
time.sleep(E_DELAY)
GPIO.output(LCD_E, True)
time.sleep(E_PULSE)
GPIO.output(LCD_E, False)
time.sleep(E_DELAY)
# Low bits
if bits&0x01==0x01:
if bits&0x02==0x02:
if bits&0x04==0x04:
if bits&0x08==0x08:
time.sleep(E_DELAY)
time.sleep(E_PULSE)
time.sleep(E_DELAY)
if __name__ == '__main__':
main()
Output displayed here on one of my new LCD add on boards :
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation
