I use command
wget http://pypi.python.org/packages/source/ ... e859ded153
and result is
--2012-11-04 07:24:06-- http://pypi.python.org/packages/source/ ... .1a.tar.gz
Resolving pypi.python.org (pypi.python.org)... failed: No address associated with hostname.
wget: unable to resolve host address `pypi.python.org'
What is something wrong?
How to get Library pyhton GPIO
Hi Every one
I new user for Linux and Raspberry Pi.
How to get Library pyhton GPIO.
I Have problem in attach picture.
- Attachments
- ScreenHunter_01 Nov. 04 14.26.jpg (32.03 KiB) Viewed 897 times
RPi.GPIO is included in the latest Raspbian edition.
If it's not on the one you've got, you can easily
or...
From your error message it looks like your connection may have failed.
- Code: Select all
sudo apt-get update
sudo apt-get install rpi.gpio
or...
- Code: Select all
sudo apt-get install python-pip
sudo pip install rpi.gpio
If you are running a current form of raspbian then it's pre installed.
Thank you for your recommend
Its possible to manualy install a lib ?
I want do create a plugin for Openelec to use interaction between the movie and some lights.
Openelec have python, but not the GPIO lib.
Maybe I can install it on some shared lib, or as a resource from the plugin.
Any ideias ?
Any ideias ?
angusbrasil wrote:Its possible to manualy install a lib ?
Any ideias ?
RPi.GPIO is a python package that is on pypi, so it is very easy to install, using either easy_install or pip. I'm not going to retype all of this though, just check the beginning of this article:
http://raspberry-python.blogspot.com/2012/10/rpigpio-dot-dash.html
François
Francois
http://raspberry-python.blogspot.com - @f_dion
But on OpenElec I dont have "apt-get", so I cant install the setup tools to use "easy_install".
angusbrasil wrote:But on OpenElec I dont have "apt-get", so I cant install the setup tools to use "easy_install".
Just go here: http://pypi.python.org/pypi/setuptools
Download the setuptools-0.6c11-py2.7.egg and then:
- Code: Select all
$ sudo sh setuptools-0.6c11-py2.7.egg
And you will have easy_install. Then you can sudo easy_install RPi.GPIO
Francois
Francois
It dont work that easy to me.
When I try to install the egg, i got this message.
setuptools-0.6c11-py2.7.egg: line 3: exec: python2.7: not found
I also try with the paramters --prefix=/usr/lib/python
I dont no if that python from openelec is incompleted.
So I download the 2.7 version, and try to install, but without success too.
./configure: line 429: expr: command not found
./configure.lineno: line 429: expr: command not found
I give up and install raspbmc that aready have gpio support and agt-get
