Hey, I'm fairly new to linux and looked around the net about makefiles but I can't really seem to make sense of any of them. I was wondering if someone could explain how you would compose your own makefile and what it actually does.
Thank you
MakeFiles
I typed "makefiles explained" in google.
I think this one is not too bad:
http://www.google.co.uk/url?sa=t&rct=j&q=makefiles+explained&source=web&cd=3&ved=0CFkQFjAC&url=http%3A%2F%2Fwww.cs.uiuc.edu%2Fclass%2Ffa05%2Fcs225%2Fcs225%2F_resources%2F_tutorials%2FmakeTut.pdf&ei=338hUKWLJtC20QXAzYHQAg&usg=AFQjCNGS2pPf7hTmDVuUtwFSMp6vdaGd6A
However none of the manuals will make much sens unless you have compiled programs yourself and thus
have some idea what linux commands look like, how to compile/assemble/link or in general how to build computer 'stuff'.
Johnathon332 wrote:Hey, I'm fairly new to linux and looked around the net about makefiles but I can't really seem to make sense of any of them. I was wondering if someone could explain how you would compose your own makefile and what it actually does.
Thank you
A Makefile is essentially a file with instructions about how to do stuff.
So it contains a simple variable mechanism
foo = 123
and a set of rules that say
this depends on that
which then translate to
if that has changed, then to this
So if you have a project that involves more than one file and you change one file, you only need to re-compile that single file, then link the binaries together. This is much more efficient than recompiling 30 files each time something changes.
Another way to view a Makefile is that it's actually a progrmaming language - you're writing a program to control the comilition of your other programs - however it's a pretty eseoteric "language" if viewd that way.
There are 1000's of resources online about Makefiles and an O'Reilly book (or 2), but if you want some simple exanples, then have a look at my wiringPi library - it uses Makefiles to compile and link the files together.
https://projects.drogon.net/raspberry-pi/wiringpi/download-and-install/
Just one thing to remember about Makefiles - spaces and tab's are treated differently! IF you ever copy & paste a Makefile, or bits of one then it may change tabs into spaces and it'll stop working. Thats trips up a lot of newcomes to makefiles!
-Gordon
