Wifi
Hi I have got a wifi adapter, how do I get it t work I have done nothing with it yet?? Thanks
Luke269 wrote:Hi I have got a wifi adapter, how do I get it t work I have done nothing with it yet?? Thanks
Searching the forum might give some clues, otherwise tell us what OS and Wifi adapter you have and we'll have a better change of helping.
It has no brand, it come with cd though. I copied the cd setup files to USB but the raspberry pi won't read .exe files. Is there another way. Can get this to work? Thanks
plug the wifi adapter in to the pi then type
lsusb
and paste up what it displays
lsusb
Command not found
Interesting. Are you sure it was typed right? that's l s u s b . What OS are you running?
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
I am using debian, I yes I have typed it properly:)
Luke269 wrote:I am using debian, I yes I have typed it properly:)
I'm not sure then...I'm assuming the standard Debian Squeeze...not Debian Wheezy alpha or Raspbian?
Hi, thanks for your help so for it is normal squeeze. I will try again tomorrow and what is the code? Do I type it on terminal? Sudo at the start? And does it begin with I or one? Thank you
Luke269 wrote:Hi, thanks for your help so for it is normal squeeze. I will try again tomorrow and what is the code? Do I type it on terminal? Sudo at the start? And does it begin with I or one? Thank you
In a terminal. It starts with an L. I suspect that is your problem.
It doesn't show anything it just goes down a line without it typing anything first.
search.php?keywords=wifi returns lots of results (some of which may be useful) and it's also worth looking at http://elinux.org/RPi_Peripherals
thanks, that didnt work but are they the exact instructions for TP-Link TL-WN722N USB, as i am thinking about getting that one to make it easier. thanks:)
