Wifi
by Luke269 » Sat Jun 23, 2012 6:11 pm
Hi I have got a wifi adapter, how do I get it t work I have done nothing with it yet?? Thanks
by Lorian » Sat Jun 23, 2012 6:26 pm
Luke269 wrote:Hi I have got a wifi adapter, how do I get it t work I have done nothing with it yet?? Thanks
Searching the forum might give some clues, otherwise tell us what OS and Wifi adapter you have and we'll have a better change of helping.
by Luke269 » Sat Jun 23, 2012 7:08 pm
It has no brand, it come with cd though. I copied the cd setup files to USB but the raspberry pi won't read .exe files. Is there another way. Can get this to work? Thanks
by Lorian » Sat Jun 23, 2012 7:13 pm
plug the wifi adapter in to the pi then type
lsusb
and paste up what it displays
by Luke269 » Sat Jun 23, 2012 7:26 pm
Command not found
by JeremyF » Sat Jun 23, 2012 8:01 pm
Interesting. Are you sure it was typed right? that's l s u s b . What OS are you running?
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by Luke269 » Sat Jun 23, 2012 8:05 pm
I am using debian, I yes I have typed it properly:)
by JeremyF » Sat Jun 23, 2012 9:03 pm
Luke269 wrote:I am using debian, I yes I have typed it properly:)
I'm not sure then...I'm assuming the standard Debian Squeeze...not Debian Wheezy alpha or Raspbian?
by Luke269 » Sat Jun 23, 2012 9:11 pm
Hi, thanks for your help so for it is normal squeeze. I will try again tomorrow and what is the code? Do I type it on terminal? Sudo at the start? And does it begin with I or one? Thank you :)
by JeremyF » Sat Jun 23, 2012 9:14 pm
Luke269 wrote:Hi, thanks for your help so for it is normal squeeze. I will try again tomorrow and what is the code? Do I type it on terminal? Sudo at the start? And does it begin with I or one? Thank you :)
In a terminal. It starts with an L. I suspect that is your problem. :)
by Luke269 » Sun Jun 24, 2012 9:34 am
It doesn't show anything it just goes down a line without it typing anything first.
by AndrewS » Sun Jun 24, 2012 10:56 am
search.php?keywords=wifi returns lots of results (some of which may be useful) and it's also worth looking at http://elinux.org/RPi_Peripherals
by Luke269 » Sun Jun 24, 2012 5:19 pm
thanks, that didnt work but are they the exact instructions for TP-Link TL-WN722N USB, as i am thinking about getting that one to make it easier. thanks:)
