Tiny Image?
I have a few small SD cards. Are there any tiny standalone images with maybe just diagnostics or a single small standalone demo.
Rename kernel_emergency.img to kernel.img
(it contains an embedded filesystem image)
Edit: you also need some other files too - more details in a few minutes...
Okay, after a bit of a delay, I've now updated http://www.andrewscheller.co.uk/rpi_emergency.zip to the latest versions available. Instructions same as before: viewtopic.php?p=87637#p87637
It doesn't do much, but at least it gives you a very minimal Linux system, that will run from any SD card
