Hi Guys
Are there any tutorials on compiling programs to run on the Raspberry Pi that arn't already ARM?
Compiling Programs for the Pi
Owner of: http://www.fusionstrike.com - I make gorgeous Raspberry Pi Tutorials
Most programs you compile "aren't ARM". Linux software is largely written in C or C++, which are (for the most part) architecture-independent languages. When you compile a program, the compiler (usually GCC) converts this high-level C code into low-level (binary) ARM code.
So most code doesn't need any "conversion" to ARM, just compile it and run
(on your regular PC, GCC will convert the same C code into binary x86 code)
However there are a few special cases in which code might be architecture-specific if it's very highly optimised or contains inline assembler. In these cases there's nothing you can "easily" do to compile it for ARM, you need to wait for somebody (probably the initial author) to create ARM-specific versions of these parts of the code.
I am trying to compile this: http://www.df.lth.se/~pi/mongo_big_endian.html
Which is an ARM version of MongoDB, although when I am I'm getting this error:
- Code: Select all
root@raspberrypi:~/mongo# scons
scons: Reading SConscript files ...
scons version: 2.0.0.final.0
python version: 2 6 6 'final' 0
warning: using ubuntu without xulrunner-dev. we recommend installing it
Checking whether the C++ compiler worksyes
Checking for C library stdc++... yes
Checking for C++ header file pcrecpp.h... yes
Checking for C++ header file boost/filesystem/operations.hpp... no
can't find boost headers
I believe MongoDB is already available for the RaspPi (sudo apt-get install MongoDB). Is there some reason you want to compile it?
It looks like it's missing some dependencies. Try installing the dev package of "boost" whatever that is.
rurwin wrote:It looks like it's missing some dependencies. Try installing the dev package of "boost" whatever that is.
Boost is a very popular C++ template library (or rather a collection of libraries). Most of what gets added into newer C++ revisions usually comes from Boost.
rurwin wrote:I believe MongoDB is already available for the RaspPi (sudo apt-get install MongoDB). Is there some reason you want to compile it?
Unfortunately it doesn't seem to be available as I get the error no package found
- Code: Select all
Last login: Thu May 31 00:07:48 2012 from 192.168.2.11
root@raspberrypi:~# sudo apt-get install MongoDB
Reading package lists... Done
Building dependency tree
E: Unable to locate package MongoDB
root@raspberrypi:~#
According to http://packages.debian.org/squeeze/mongodb there's two problems:
1) the package name is all lower-case
2) it's not available for armel
P.S. Looks like this is the boost package you're missing http://packages.debian.org/squeeze/libboost-dev
so: "sudo apt-get install libboost-dev"
AndrewS wrote:According to http://packages.debian.org/squeeze/mongodb there's two problems:
1) the package name is all lower-case![]()
I managed to get that working, but now I get the error:
- Code: Select all
Checking for C++ header file boost/filesystem/operations.hpp... yes
Checking for C library boost_system-mt... yes
Checking for C library boost_thread-mt... yes
Checking for C library boost_filesystem-mt... yes
Checking for C library boost_program_options-mt... yes
Checking for C++ header file execinfo.h... yes
Checking for C library pcrecpp... yes
Checking for C library pcre... yes
Checking for C library pcap... no
Checking for C library wpcap... no
Checking for C library mozjs... no
Checking for C library js... no
Checking for C library js_static... no
can't find or link against library ['mozjs', 'js', 'js_static'] in []
see config.log for more information
root@raspberrypi:~/mongo# mongo
I managed to get my favourite toy program, xswarm, running with the following. A dump of my command history follows.
Amazed that an old program (1990) still compiles and works for X11 out of the box, and it is such a short program.
Did require a lot of packages added to support the compile of X11 programs.
I'm using Debian squeeze, debian6-19-04-2012
From Windows I'm using xming for an X display with putty for normal ssh use.
http://sourceforge.net/projects/xming/
http://www.putty.org/
The Pi is fun.
The Pi is fun.
- Code: Select all
421 wget http://sparemint.atariforge.net/sparemint/SRPMS/xswarm-2.3-1.src.rpm
422 mkdir xswarm
423 cd xswarm
424 rpm2cpio ../xswarm-2.3-1.src.rpm > xswarm.cpio
425 cpio -i --make-directories < xswarm.cpio
428 tar -zxvf xswarm-2.3.tar.gz
429 cd xswarm-2.3
453 sudo apt-get install xorg-dev
473 gcc -I /usr/include/X11 -L/usr/lib -lX11 -oxswarm xswarm.c
475 ./xswarm -h
499 ./xswarm -wyellow -cred -b500
500 man -l xswarm.man
usbspyder wrote:Amazed that an old program (1990) still compiles and works for X11 out of the box, and it is such a short program.
The "advantage" of programming directly against Xlib and not using some fancy higher-level GUI toolkit/framework/desktop-environment
For MongoDB on ARM this issue is relevant: https://jira.mongodb.org/browse/SERVER-1811
On Debian there seems to be a working package but ArchLinux hasn't and officially it isn't supported
