Cross compiled kernel won't boot
by honda4life » Thu Jun 28, 2012 9:47 pm
I've followed this wiki under Ubuntu:
http://elinux.org/Rpi_kernel_compilation#Ubuntu_Linux
Copied the config as described and afterwards menuconfig to enable PPP filtering.
Build completed, copied the kernel en ending with the "test screen".
i've copied the latest kernel from github to /boot/ so the other files should be up-to-date ;)
What can I do wrong with this, it should be so easy...
Who has a clue?
by Killerbee » Fri Jun 29, 2012 7:30 am
If I understand you correct you are able to compile a new kernel.
Are you able to convert the kernel to a kernel.img file using this command?
python imagetool-uncompressed.py path/to/linux/arch/arm/boot/Image
If it works you will find a kernel.img file. Copy this file to your SD card's /boot directory
At least your pi should boot.
Please let me know if you pi boots because we need to copy the modules also
KB
by dom » Fri Jun 29, 2012 8:48 am
Actually this is now optional. Recent firmwares will accept the "Image" file directly (just renamed to kernel.img).
Moderator
by Killerbee » Fri Jun 29, 2012 11:22 am
Nice :) thanks but does it work with the ZImage as well?
by dom » Fri Jun 29, 2012 11:31 am
Killerbee wrote:Nice :) thanks but does it work with the ZImage as well?
No.
Moderator
by honda4life » Sat Jun 30, 2012 7:20 am
Yes, compilation is ok
Indeed commands aren't needed ;)
