Virtuella RAM and cpu clock
by bastian94 » Thu Aug 02, 2012 8:07 am
can i use a flash drive to extend the ram and maby use it to extensd the cpu clock
by emba » Thu Aug 02, 2012 9:21 am
I wouldn't think so, technically you could mount swap file on a usb drive but it won't help your cpu clocks and probably wouldn't make much difference
by RaTTuS » Thu Aug 02, 2012 9:36 am
you can have a swap partition on a external HD [try not to use flash as it will die fast [ depending]]
you cannot increase the cpu clock speed with anything plugged in - though you can overclock it
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by bastian94 » Thu Aug 02, 2012 1:24 pm
and how would a do that can you post a link to a tutorial
by RaTTuS » Thu Aug 02, 2012 1:26 pm
