SSD Tweaks
by bumblebizzle » Fri Jul 27, 2012 6:41 am
There were a couple of tweaks I'd use on my Asus EeePC to tweak the SSD speed and extend it's life. Will these same tweaks work on the Raspberry Pi?
fstab: "/ ext4 discard,noatime,nodirtime"
... there's no hard disk controller so should I use 'discard'
IO Scheduler: "cat /sys/block/sdX/queue/scheduler"
... couldn't find which scheduler is being used ... is it even necessary?
Thanks for any suggestions :)
by AndrewS » Fri Jul 27, 2012 11:15 am
discard - no idea if it will help
noatime - sure :)
nodiratime - viewtopic.php?p=132419#p132419 says it's not needed
Regarding the scheduler - again I have no idea if it'll make any difference, but on the RPi you can see the current setting with
cat /sys/block/mmcblk0/queue/scheduler
Much more info in this thread viewtopic.php?f=29&t=11767 (and the other threads it links to).
by vmp32k » Fri Jul 27, 2012 3:20 pm
A quick google'ing about discard yields: https://patrick-nagel.net/blog/archives/337
with “discard” on, deleting a big bunch of small files is 64 times slower on my SSD. For those ~40 seconds any I/O is really slow
I would leave it off. Besides, I'm not sure if a SD-card qualifies as a full-blown SSD with Trim support. ;)
by bumblebizzle » Fri Jul 27, 2012 5:41 pm
Cool! Thanks for the feedback. Leaving /etc/fstab in its original form. I just got my Pi yesterday and had a whole 30 minutes to play with it before running off to work. Tinkering/surfing/posting with the little beast now. 8-)
IO Scheduler:
cat /sys/block/mmcblk0/queue/scheduler = deadline ... changed it to noop via echo noop > /sys/block/mmcblk0/queue/scheduler ... will see how things go. :geek:
