Future (turbo) expansion board?
Would it be possible to connect a "turbo board" to the GPIO connector? This board could have a quad or octo core ARM chip, 1Gb ram, and wifi. The world is your oyster...
You can use the turbo board on its own if it is so powerful
This is already done, using a powerful server communicating with the R-PI over ethernet with an R-PI, which is doing the video rendering, and accepting keyboard and mouse I/O, its called a
"Citrix’s XenDesktop remote desktop", and there was piece about it on the home page a short while ago.
http://www.raspberrypi.org/archives/1222
by the way, the GPIO port probably won't provide enough bandwidth, to do this, so using ethernet is a better choice.
why would you connect a more powerfull machine as a "expansion" to a slower machine? But yes it is possible if the other board has GPIO too, you can implement a simple protocol like SPI and exchange data i think
mahjongg wrote:by the way, the GPIO port probably won't provide enough bandwidth, to do this, so using ethernet is a better choice.
Actually, the SPI bus (available on the GPIO connector) is potentially higher-banwidth than Ethernet
https://en.wikipedia.org/wiki/Serial_Pe ... erface_Bus
Some ethernet chips actually interface to the host CPU / microcontoller via SPI (unlike the ethernet chip on the Raspi, which interfaces via USB)
For really high speed use a DSI to CSI connection: 1.2Gbps
Gert van Loo wrote:For really high speed use a DSI to CSI connection: 1.2Gbps
I thought on the RPi the DSI and CSI interfaces were entirely GPU-side, i.e. not usable by anyone outside Broadcom?
