FYI: HDMI resolution regression?
by Bakul Shah » Sun Jun 03, 2012 12:04 am
The latest start.elf from the firmware git repo (commit dated Thu May 31 13:58:04 2012 +0100) put my hdmi TV in 640x480 mode! I git reset it to the previous version and the TV resolution went back to 1920x1080 @60Hz. Not sure if this exposes a bug in my TV or the latest start.elf : )
by dom » Sun Jun 03, 2012 9:15 am
Can you show contents of your config.txt and post your EDID.
/opt/vc/bin/tvservice -d edid.dat
Moderator
by Bakul Shah » Sun Jun 03, 2012 11:58 pm
There is no config.txt. EDID (via edidparser):
HDMI:EDID version 1.3, 1 extensions, screen size 82x46 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 50-77 Hz, horizontal is 31-70 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is SV370XVT
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID established timing I/II bytes are AF CE 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
HDMI:EDID found audio format 2 channels AC3, sample rate: 32|44|48 kHz, bitrate: 24 kbps
HDMI:EDID found HDMI VSDB length 6
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:no
HDMI:EDID HDMI VSDB has no latency information
HDMI:Warning EDID must support pcm or no audio
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID filtering out CEA format: 640x480p @ 60 Hz (1) with pixel clock 25 MHz and hfp:16 hs:96 hbp:48
HDMI:EDID filtering out CEA format: 720x480p @ 60 Hz (2) with pixel clock 27 MHz and hfp:16 hs:62 hbp:60
HDMI:EDID filtering out CEA format: 720x480p @ 60 Hz (3) with pixel clock 27 MHz and hfp:16 hs:62 hbp:60
HDMI:EDID filtering out CEA format: 1280x720p @ 60 Hz (4) with pixel clock 74 MHz and hfp:110 hs:40 hbp:220
HDMI:EDID filtering out DMT format: 640x480p @ 60 Hz (4) with pixel clock 25 MHz and hfp:16 hs:96 hbp:48
HDMI:EDID filtering out CEA format: 1920x1080i @ 60 Hz (5) with pixel clock 74 MHz and hfp:88 hs:44 hbp:148
HDMI:EDID filtering out DMT format: 640x480p @ 72 Hz (5) with pixel clock 31 MHz and hfp:24 hs:40 hbp:128
HDMI:EDID filtering out DMT format: 640x480p @ 75 Hz (6) with pixel clock 31 MHz and hfp:16 hs:64 hbp:120
HDMI:EDID filtering out DMT format: 800x600p @ 56 Hz (8) with pixel clock 36 MHz and hfp:24 hs:72 hbp:128
HDMI:EDID filtering out DMT format: 800x600p @ 60 Hz (9) with pixel clock 40 MHz and hfp:40 hs:128 hbp:88
HDMI:EDID filtering out DMT format: 800x600p @ 72 Hz (10) with pixel clock 50 MHz and hfp:56 hs:120 hbp:64
HDMI:EDID filtering out DMT format: 800x600p @ 75 Hz (11) with pixel clock 49 MHz and hfp:16 hs:80 hbp:160
HDMI:EDID filtering out CEA format: 1920x1080p @ 60 Hz (16) with pixel clock 148 MHz and hfp:88 hs:44 hbp:148
HDMI:EDID filtering out DMT format: 1024x768p @ 60 Hz (16) with pixel clock 65 MHz and hfp:24 hs:136 hbp:160
HDMI:EDID filtering out CEA format: 720x576p @ 50 Hz (17) with pixel clock 27 MHz and hfp:12 hs:64 hbp:68
HDMI:EDID filtering out DMT format: 1024x768p @ 70 Hz (17) with pixel clock 75 MHz and hfp:24 hs:136 hbp:144
HDMI:EDID filtering out CEA format: 720x576p @ 50 Hz (18) with pixel clock 27 MHz and hfp:12 hs:64 hbp:68
HDMI:EDID filtering out DMT format: 1024x768p @ 75 Hz (18) with pixel clock 78 MHz and hfp:16 hs:96 hbp:176
HDMI:EDID filtering out CEA format: 1280x720p @ 50 Hz (19) with pixel clock 74 MHz and hfp:440 hs:40 hbp:220
HDMI:EDID filtering out CEA format: 1920x1080i @ 50 Hz (20) with pixel clock 74 MHz and hfp:528 hs:44 hbp:148
HDMI:EDID filtering out CEA format: 1440x576i @ 50 Hz (21) with pixel clock 27 MHz and hfp:24 hs:126 hbp:138
HDMI:EDID filtering out CEA format: 1920x1080p @ 50 Hz (31) with pixel clock 148 MHz and hfp:528 hs:44 hbp:148
HDMI:EDID filtering out CEA format: 1920x1080p @ 24 Hz (32) with pixel clock 74 MHz and hfp:638 hs:44 hbp:148
HDMI:EDID filtering out CEA format: 1920x1080p @ 25 Hz (33) with pixel clock 74 MHz and hfp:528 hs:44 hbp:148
HDMI:EDID preferred mode is updated to CEA (1) 640x480p @ 60 Hz with pixel clock 25200000 Hz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
by dom » Mon Jun 04, 2012 12:01 am
Can you post result of
/opt/vc/bin/vcgencmd version
Can you attach the actual binary edid file here (using "upload attachment")
Moderator
by Bakul Shah » Mon Jun 04, 2012 12:07 am
dom wrote:Can you post result of
May 31 2012 13:35:03
Copyright (c) 2012 Broadcom
version 317494 (release)
Hmm... it won't let me attach a binary file....
Or even .txt file! Suggestion?
Sent in email to dom
